[Qgis-developer] Attribute table opening several instances
    Nathan Woodrow
    madmanwoo at gmail.com
    Thu Jun 19 13:04:40 PDT 2014
I think the current way it works is correct.  There have been times when I
wanted to compare the full table to a selection.
Nathan
On Jun 20, 2014 6:00 AM, "AntonioLocandro" <antoniolocandro at hotmail.com>
wrote:
> Is there any use case where having the possibility of opening several times
> the same attribute table for a layer useful? Right now when opening
> attribute table on a layer you can open n attribute tables if you don't
> previously close it.
> I would think if you already have an opened attribute table for a layer and
> then clic Open Attribute table it should open a new window unless there is
> already one open, in that case it should focus the previously opened table
> respecting any formatting on it
> http://osgeo-org.1560.x6.nabble.com/Attribute-table-opening-several-instances-tp5146844.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140620/8a18eb88/attachment.html>
