[Qgis-developer] Attribute table opening several instances
AntonioLocandro
antoniolocandro at hotmail.com
Thu Jun 19 13:00:15 PDT 2014
Is there any use case where having the possibility of opening several times
the same attribute table for a layer useful? Right now when opening
attribute table on a layer you can open n attribute tables if you don't
previously close it.
I would think if you already have an opened attribute table for a layer and
then clic Open Attribute table it should open a new window unless there is
already one open, in that case it should focus the previously opened table
respecting any formatting on it
View this message in context: http://osgeo-org.1560.x6.nabble.com/Attribute-table-opening-several-instances-tp5146844.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
