[Qgis-developer] qgis-server will crash on a specific project
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sun Jun 22 03:07:11 PDT 2014
It is a problem with the layer cache. Will provide a fix for that soon.
Regards,
Marco
On 22.06.2014 11:49, Andrea Peri wrote:
> Hi,
> I confirm.
> There is a layer limit in QGIS-Server
> I do a huge test removing one by one all the layers from my project.
> And after the removing of every single layer I retest the working.
> Aftr a while of time. I reach the limit.
> And the project begin to run.
> I do other test to exclude that was the number of layer inside a single group.
> All the test give the response that seem to be the max number of
> layers in a project.
> So the question is:
> QGIS desktop allow to put more layers rather than how many are
> accepted from qgis-server.
> This not good for a WYSIWYG system.
> Ok, I will try to patch my server when found exactly where is the problem.
> Meanwhile,
> Now the question is on what structure is this limit ?
> I don't guess it is simply a layer limit but perhaps a more specific structure.
> Now I have a project that crash , and a project with a one less layer that work.
> Doing a DIFF beetween the two projects I see the possible structure
> breakable are:
> layer-tree-canvas -> custom-order -> item
> maplayer
> Digitizing -> LayerSnappingList -> value   (type QStringList)
> Digitizing -> LayerSnappingEnabledList -> value   (type QStringList)
> Digitizing -> LayerSnapToList -> value   (type QStringList)
> Digitizing -> LayerSnappingToleranceList -> value   (type QStringList)
> I check if in the code there is a limited array dimension for this objects.
> Regards,
> Andrea.
> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi,
>> I do some other tests.
>> I take my project that give QG crash and split it in two compementary projects.
>> Of course I do this using qgis desktop to avoid unvolontary errors.
>> Testing both of them on QS there is no crash !
>> So:
>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>> to the number of Groups or Layers it can have in a project.
>> A limit different (and less) than qgis desktop (osgeo4w version).
>> Is this a plausible theory ?
>> Thx,
>> Andrea.
>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>> Hi,
>>> I have a qgis-server that will crash on a specific project.
>>> The qgis-server will run correctly with another project that seem
>>> almost similar (both use the SVG symbols).
>>> The project that crash my QG  run correctly and smootly on a qgis
>>> desktop (qgis-dev) on a windows system.
>>> The project use SVG symbols, but also the other project I test on
>>> QSused SVG symbol
>>> so I suppose the SVG engine is ok.
>>> Also I check t have set correctly the SVG paths.
>>> Also I update to the very last (about 4 hours ago) master version.
>>> After all this check the qgis-server still crash.
>>> So I try to set the logfile, but the log is always empty.
>>> This mean that the cgi qgis-server will crash almost immediatly.
>>> So I set an environment shell to run it manually and to test the cgi
>>> with a gdb session.
>>> The results are this:
>>> [Thread debugging using libthread_db enabled]
>>> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>> environment variable.
>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>> Program received signal SIGSEGV, Segmentation fault.
>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>     from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>> (gdb)
>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>> But another project will run without any apparent problem.
>>> Many thx for every hint.
>>> Andrea Peri
>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
