[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri
aperi2007 at gmail.com
Sun Jun 22 03:12:04 PDT 2014
thx for response.
meanwhile,
I notice that the max allowed layers is exactly 101.
This mean (knowing C/C++) an array of 100 elements.
Searching for this particular value,
i find in the file "mapserver/qgsmslayercache.cpp"
is defined
mDefaultMaxLayers = 100;
if not defined the environment variable "MAX_CACHE_LAYERS"
char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
if ( maxLayerEnv )
So a possible solution could be to set this environment variable.
I try and report.
Regards,
Andrea.
2014-06-22 12:07 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> It is a problem with the layer cache. Will provide a fix for that soon.
> Regards,
> Marco
> On 22.06.2014 11:49, Andrea Peri wrote:
>> Hi,
>> I confirm.
>> There is a layer limit in QGIS-Server
>> I do a huge test removing one by one all the layers from my project.
>> And after the removing of every single layer I retest the working.
>> Aftr a while of time. I reach the limit.
>> And the project begin to run.
>> I do other test to exclude that was the number of layer inside a single
>> group.
>> All the test give the response that seem to be the max number of
>> layers in a project.
>> So the question is:
>> QGIS desktop allow to put more layers rather than how many are
>> accepted from qgis-server.
>> This not good for a WYSIWYG system.
>> Ok, I will try to patch my server when found exactly where is the problem.
>> Meanwhile,
>> Now the question is on what structure is this limit ?
>> I don't guess it is simply a layer limit but perhaps a more specific
>> structure.
>> Now I have a project that crash , and a project with a one less layer that
>> work.
>> Doing a DIFF beetween the two projects I see the possible structure
>> breakable are:
>> layer-tree-canvas -> custom-order -> item
>> maplayer
>> Digitizing -> LayerSnappingList -> value (type QStringList)
>> Digitizing -> LayerSnappingEnabledList -> value (type QStringList)
>> Digitizing -> LayerSnapToList -> value (type QStringList)
>> Digitizing -> LayerSnappingToleranceList -> value (type QStringList)
>> I check if in the code there is a limited array dimension for this
>> objects.
>> Regards,
>> Andrea.
>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>> Hi,
>>> I do some other tests.
>>> I take my project that give QG crash and split it in two compementary
>>> projects.
>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>> Testing both of them on QS there is no crash !
>>> So:
>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>> to the number of Groups or Layers it can have in a project.
>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>> Is this a plausible theory ?
>>> Thx,
>>> Andrea.
>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>> Hi,
>>>> I have a qgis-server that will crash on a specific project.
>>>> The qgis-server will run correctly with another project that seem
>>>> almost similar (both use the SVG symbols).
>>>> The project that crash my QG run correctly and smootly on a qgis
>>>> desktop (qgis-dev) on a windows system.
>>>> The project use SVG symbols, but also the other project I test on
>>>> QSused SVG symbol
>>>> so I suppose the SVG engine is ok.
>>>> Also I check t have set correctly the SVG paths.
>>>> Also I update to the very last (about 4 hours ago) master version.
>>>> After all this check the qgis-server still crash.
>>>> So I try to set the logfile, but the log is always empty.
>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>> So I set an environment shell to run it manually and to test the cgi
>>>> with a gdb session.
>>>> The results are this:
>>>> [Thread debugging using libthread_db enabled]
>>>> Using host libthread_db library
>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>> Program received signal SIGSEGV, Segmentation fault.
>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>> from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>> (gdb)
>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>> But another project will run without any apparent problem.
>>>> Many thx for every hint.
>>>> Andrea Peri
>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
Andrea Peri
qwerty àèìòù
