[Qgis-developer] qgis-server will crash on a specific project
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sun Jun 22 03:15:57 PDT 2014
>char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
This is a short-time workaround for users.
Regards,
Marco
On 22.06.2014 12:12, Andrea Peri wrote:
> Hi,
> thx for response.
> meanwhile,
> I notice that the max allowed layers is exactly 101.
> This mean (knowing C/C++) an array of 100 elements.
> Searching for this particular value,
> i find in the file "mapserver/qgsmslayercache.cpp"
> is defined
>          mDefaultMaxLayers = 100;
> if not defined the environment variable "MAX_CACHE_LAYERS"
> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>    if ( maxLayerEnv )
> So a possible solution could be to set this environment variable.
> I try and report.
> Regards,
> Andrea.
> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>> It is a problem with the layer cache. Will provide a fix for that soon.
>> Regards,
>> Marco
>> On 22.06.2014 11:49, Andrea Peri wrote:
>>> Hi,
>>> I confirm.
>>> There is a layer limit in QGIS-Server
>>> I do a huge test removing one by one all the layers from my project.
>>> And after the removing of every single layer I retest the working.
>>> Aftr a while of time. I reach the limit.
>>> And the project begin to run.
>>> I do other test to exclude that was the number of layer inside a single
>>> group.
>>> All the test give the response that seem to be the max number of
>>> layers in a project.
>>> So the question is:
>>> QGIS desktop allow to put more layers rather than how many are
>>> accepted from qgis-server.
>>> This not good for a WYSIWYG system.
>>> Ok, I will try to patch my server when found exactly where is the problem.
>>> Meanwhile,
>>> Now the question is on what structure is this limit ?
>>> I don't guess it is simply a layer limit but perhaps a more specific
>>> structure.
>>> Now I have a project that crash , and a project with a one less layer that
>>> work.
>>> Doing a DIFF beetween the two projects I see the possible structure
>>> breakable are:
>>> layer-tree-canvas -> custom-order -> item
>>> maplayer
>>> Digitizing -> LayerSnappingList -> value   (type QStringList)
>>> Digitizing -> LayerSnappingEnabledList -> value   (type QStringList)
>>> Digitizing -> LayerSnapToList -> value   (type QStringList)
>>> Digitizing -> LayerSnappingToleranceList -> value   (type QStringList)
>>> I check if in the code there is a limited array dimension for this
>>> objects.
>>> Regards,
>>> Andrea.
>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>> Hi,
>>>> I do some other tests.
>>>> I take my project that give QG crash and split it in two compementary
>>>> projects.
>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>> Testing both of them on QS there is no crash !
>>>> So:
>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>> to the number of Groups or Layers it can have in a project.
>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>> Is this a plausible theory ?
>>>> Thx,
>>>> Andrea.
>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>> Hi,
>>>>> I have a qgis-server that will crash on a specific project.
>>>>> The qgis-server will run correctly with another project that seem
>>>>> almost similar (both use the SVG symbols).
>>>>> The project that crash my QG  run correctly and smootly on a qgis
>>>>> desktop (qgis-dev) on a windows system.
>>>>> The project use SVG symbols, but also the other project I test on
>>>>> QSused SVG symbol
>>>>> so I suppose the SVG engine is ok.
>>>>> Also I check t have set correctly the SVG paths.
>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>> After all this check the qgis-server still crash.
>>>>> So I try to set the logfile, but the log is always empty.
>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>> with a gdb session.
>>>>> The results are this:
>>>>> [Thread debugging using libthread_db enabled]
>>>>> Using host libthread_db library
>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>      from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>> (gdb)
>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>> But another project will run without any apparent problem.
>>>>> Many thx for every hint.
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>>> Andrea Peri
>>>> qwerty àèìòù
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
