[Qgis-developer] qgis-server will crash on a specific project
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sun Jun 22 04:04:18 PDT 2014
It should work now. Could you test with the current git version? My test
projects are not large enough.
Regards,
Marco
On 22.06.2014 12:27, Andrea Peri wrote:
> you have right,
> it is not a good solution. Too project depending and resource consuming.
> thx for a better fixing
> A.
> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>> This is a short-time workaround for users.
>> Regards,
>> Marco
>> On 22.06.2014 12:12, Andrea Peri wrote:
>>> Hi,
>>> thx for response.
>>> meanwhile,
>>> I notice that the max allowed layers is exactly 101.
>>> This mean (knowing C/C++) an array of 100 elements.
>>> Searching for this particular value,
>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>> is defined
>>> mDefaultMaxLayers = 100;
>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>> if ( maxLayerEnv )
>>> So a possible solution could be to set this environment variable.
>>> I try and report.
>>> Regards,
>>> Andrea.
>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>> It is a problem with the layer cache. Will provide a fix for that soon.
>>>> Regards,
>>>> Marco
>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>> Hi,
>>>>> I confirm.
>>>>> There is a layer limit in QGIS-Server
>>>>> I do a huge test removing one by one all the layers from my project.
>>>>> And after the removing of every single layer I retest the working.
>>>>> Aftr a while of time. I reach the limit.
>>>>> And the project begin to run.
>>>>> I do other test to exclude that was the number of layer inside a single
>>>>> group.
>>>>> All the test give the response that seem to be the max number of
>>>>> layers in a project.
>>>>> So the question is:
>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>> accepted from qgis-server.
>>>>> This not good for a WYSIWYG system.
>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>> problem.
>>>>> Meanwhile,
>>>>> Now the question is on what structure is this limit ?
>>>>> I don't guess it is simply a layer limit but perhaps a more specific
>>>>> structure.
>>>>> Now I have a project that crash , and a project with a one less layer
>>>>> that
>>>>> work.
>>>>> Doing a DIFF beetween the two projects I see the possible structure
>>>>> breakable are:
>>>>> layer-tree-canvas -> custom-order -> item
>>>>> maplayer
>>>>> Digitizing -> LayerSnappingList -> value (type QStringList)
>>>>> Digitizing -> LayerSnappingEnabledList -> value (type QStringList)
>>>>> Digitizing -> LayerSnapToList -> value (type QStringList)
>>>>> Digitizing -> LayerSnappingToleranceList -> value (type QStringList)
>>>>> I check if in the code there is a limited array dimension for this
>>>>> objects.
>>>>> Regards,
>>>>> Andrea.
>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>> Hi,
>>>>>> I do some other tests.
>>>>>> I take my project that give QG crash and split it in two compementary
>>>>>> projects.
>>>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>>>> Testing both of them on QS there is no crash !
>>>>>> So:
>>>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>> Is this a plausible theory ?
>>>>>> Thx,
>>>>>> Andrea.
>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>> Hi,
>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>> The qgis-server will run correctly with another project that seem
>>>>>>> almost similar (both use the SVG symbols).
>>>>>>> The project that crash my QG run correctly and smootly on a qgis
>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>> The project use SVG symbols, but also the other project I test on
>>>>>>> QSused SVG symbol
>>>>>>> so I suppose the SVG engine is ok.
>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>>>> After all this check the qgis-server still crash.
>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>>>> with a gdb session.
>>>>>>> The results are this:
>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>> Using host libthread_db library
>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>> from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>> (gdb)
>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>> But another project will run without any apparent problem.
>>>>>>> Many thx for every hint.
>>>>>>> Andrea Peri
>>>>>>> qwerty àèìòù
>>>>>> Andrea Peri
>>>>>> qwerty àèìòù
>>>> Dr. Marco Hugentobler
>>>> Sourcepole - Linux & Open Source Solutions
>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>> Technical Advisor QGIS Project Steering Committee
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
