[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri aperi2007 at gmail.com
Sun Jun 22 04:48:42 PDT 2014
I tested it but don't seem work.
I'm using the master, is that ?
A.
2014-06-22 13:04 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> It should work now. Could you test with the current git version? My test
> projects are not large enough.
> Regards,
> Marco
> On 22.06.2014 12:27, Andrea Peri wrote:
>> you have right,
>> it is not a good solution. Too project depending and resource consuming.
>> thx for a better fixing
>> A.
>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>> This is a short-time workaround for users.
>>> Regards,
>>> Marco
>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>> Hi,
>>>> thx for response.
>>>> meanwhile,
>>>> I notice that the max allowed layers is exactly 101.
>>>> This mean (knowing C/C++) an array of 100 elements.
>>>> Searching for this particular value,
>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>> is defined
>>>>           mDefaultMaxLayers = 100;
>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>     if ( maxLayerEnv )
>>>> So a possible solution could be to set this environment variable.
>>>> I try and report.
>>>> Regards,
>>>> Andrea.
>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>> It is a problem with the layer cache. Will provide a fix for that soon.
>>>>> Regards,
>>>>> Marco
>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>> Hi,
>>>>>> I confirm.
>>>>>> There is a layer limit in QGIS-Server
>>>>>> I do a huge test removing one by one all the layers from my project.
>>>>>> And after the removing of every single layer I retest the working.
>>>>>> Aftr a while of time. I reach the limit.
>>>>>> And the project begin to run.
>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>> single
>>>>>> group.
>>>>>> All the test give the response that seem to be the max number of
>>>>>> layers in a project.
>>>>>> So the question is:
>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>> accepted from qgis-server.
>>>>>> This not good for a WYSIWYG system.
>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>> problem.
>>>>>> Meanwhile,
>>>>>> Now the question is on what structure is this limit ?
>>>>>> I don't guess it is simply a layer limit but perhaps a more specific
>>>>>> structure.
>>>>>> Now I have a project that crash , and a project with a one less layer
>>>>>> that
>>>>>> work.
>>>>>> Doing a DIFF beetween the two projects I see the possible structure
>>>>>> breakable are:
>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>> maplayer
>>>>>> Digitizing -> LayerSnappingList -> value   (type QStringList)
>>>>>> Digitizing -> LayerSnappingEnabledList -> value   (type QStringList)
>>>>>> Digitizing -> LayerSnapToList -> value   (type QStringList)
>>>>>> Digitizing -> LayerSnappingToleranceList -> value   (type QStringList)
>>>>>> I check if in the code there is a limited array dimension for this
>>>>>> objects.
>>>>>> Regards,
>>>>>> Andrea.
>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>> Hi,
>>>>>>> I do some other tests.
>>>>>>> I take my project that give QG crash and split it in two compementary
>>>>>>> projects.
>>>>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>>>>> Testing both of them on QS there is no crash !
>>>>>>> So:
>>>>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>> Is this a plausible theory ?
>>>>>>> Thx,
>>>>>>> Andrea.
>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>> Hi,
>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>> The qgis-server will run correctly with another project that seem
>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>> The project that crash my QG  run correctly and smootly on a qgis
>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>> The project use SVG symbols, but also the other project I test on
>>>>>>>> QSused SVG symbol
>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>>>>> with a gdb session.
>>>>>>>> The results are this:
>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>> Using host libthread_db library
>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>       from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>> (gdb)
>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>> But another project will run without any apparent problem.
>>>>>>>> Many thx for every hint.
>>>>>>>> Andrea Peri
>>>>>>>> qwerty àèìòù
>>>>>>> Andrea Peri
>>>>>>> qwerty àèìòù
>>>>> Dr. Marco Hugentobler
>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>> Technical Advisor QGIS Project Steering Committee
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andrea Peri
qwerty àèìòù
