[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri aperi2007 at gmail.com
Sun Jun 22 05:22:56 PDT 2014
No,
sorry , my wrong.
The workaround MAX_CACHE_LAYERS still work.
A.
2014-06-22 14:01 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi Marco, other information:
> The
> MAX_CACHE_LAYERS workarund
> Now seem do not work anymore.
> 2014-06-22 13:48 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi,
>> I tested it but don't seem work.
>> I'm using the master, is that ?
>> A.
>> 2014-06-22 13:04 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>>> It should work now. Could you test with the current git version? My test
>>> projects are not large enough.
>>> Regards,
>>> Marco
>>> On 22.06.2014 12:27, Andrea Peri wrote:
>>>> you have right,
>>>> it is not a good solution. Too project depending and resource consuming.
>>>> thx for a better fixing
>>>> A.
>>>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>>>> This is a short-time workaround for users.
>>>>> Regards,
>>>>> Marco
>>>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>>>> Hi,
>>>>>> thx for response.
>>>>>> meanwhile,
>>>>>> I notice that the max allowed layers is exactly 101.
>>>>>> This mean (knowing C/C++) an array of 100 elements.
>>>>>> Searching for this particular value,
>>>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>>>> is defined
>>>>>>           mDefaultMaxLayers = 100;
>>>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>>>     if ( maxLayerEnv )
>>>>>> So a possible solution could be to set this environment variable.
>>>>>> I try and report.
>>>>>> Regards,
>>>>>> Andrea.
>>>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>>>> It is a problem with the layer cache. Will provide a fix for that soon.
>>>>>>> Regards,
>>>>>>> Marco
>>>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>>>> Hi,
>>>>>>>> I confirm.
>>>>>>>> There is a layer limit in QGIS-Server
>>>>>>>> I do a huge test removing one by one all the layers from my project.
>>>>>>>> And after the removing of every single layer I retest the working.
>>>>>>>> Aftr a while of time. I reach the limit.
>>>>>>>> And the project begin to run.
>>>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>>>> single
>>>>>>>> group.
>>>>>>>> All the test give the response that seem to be the max number of
>>>>>>>> layers in a project.
>>>>>>>> So the question is:
>>>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>>>> accepted from qgis-server.
>>>>>>>> This not good for a WYSIWYG system.
>>>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>>>> problem.
>>>>>>>> Meanwhile,
>>>>>>>> Now the question is on what structure is this limit ?
>>>>>>>> I don't guess it is simply a layer limit but perhaps a more specific
>>>>>>>> structure.
>>>>>>>> Now I have a project that crash , and a project with a one less layer
>>>>>>>> that
>>>>>>>> work.
>>>>>>>> Doing a DIFF beetween the two projects I see the possible structure
>>>>>>>> breakable are:
>>>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>>>> maplayer
>>>>>>>> Digitizing -> LayerSnappingList -> value   (type QStringList)
>>>>>>>> Digitizing -> LayerSnappingEnabledList -> value   (type QStringList)
>>>>>>>> Digitizing -> LayerSnapToList -> value   (type QStringList)
>>>>>>>> Digitizing -> LayerSnappingToleranceList -> value   (type QStringList)
>>>>>>>> I check if in the code there is a limited array dimension for this
>>>>>>>> objects.
>>>>>>>> Regards,
>>>>>>>> Andrea.
>>>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>> Hi,
>>>>>>>>> I do some other tests.
>>>>>>>>> I take my project that give QG crash and split it in two compementary
>>>>>>>>> projects.
>>>>>>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>>>>>>> Testing both of them on QS there is no crash !
>>>>>>>>> So:
>>>>>>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>>>> Is this a plausible theory ?
>>>>>>>>> Thx,
>>>>>>>>> Andrea.
>>>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>> Hi,
>>>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>>>> The qgis-server will run correctly with another project that seem
>>>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>>>> The project that crash my QG  run correctly and smootly on a qgis
>>>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>>>> The project use SVG symbols, but also the other project I test on
>>>>>>>>>> QSused SVG symbol
>>>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>>>>>>> with a gdb session.
>>>>>>>>>> The results are this:
>>>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>>>> Using host libthread_db library
>>>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>>>       from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>>>> (gdb)
>>>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>>>> But another project will run without any apparent problem.
>>>>>>>>>> Many thx for every hint.
>>>>>>>>>> Andrea Peri
>>>>>>>>>> qwerty àèìòù
>>>>>>>>> Andrea Peri
>>>>>>>>> qwerty àèìòù
>>>>>>> Dr. Marco Hugentobler
>>>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
