[Qgis-developer] qgis-server will crash on a specific project
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sun Jun 22 07:01:54 PDT 2014
Just tried it with a project containing 111 layers here and the WMS
server works fine for me.
Could you check the apache error log if you are running into a server
timeout ( fcgid module kills process after some time ).
Marco
On 22.06.2014 14:22, Andrea Peri wrote:
> No,
> sorry , my wrong.
> The workaround MAX_CACHE_LAYERS still work.
> A.
> 2014-06-22 14:01 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi Marco, other information:
>> The
>> MAX_CACHE_LAYERS workarund
>> Now seem do not work anymore.
>> 2014-06-22 13:48 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>> Hi,
>>> I tested it but don't seem work.
>>> I'm using the master, is that ?
>>> A.
>>> 2014-06-22 13:04 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>>>> It should work now. Could you test with the current git version? My test
>>>> projects are not large enough.
>>>> Regards,
>>>> Marco
>>>> On 22.06.2014 12:27, Andrea Peri wrote:
>>>>> you have right,
>>>>> it is not a good solution. Too project depending and resource consuming.
>>>>> thx for a better fixing
>>>>> A.
>>>>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>>>>> This is a short-time workaround for users.
>>>>>> Regards,
>>>>>> Marco
>>>>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>>>>> Hi,
>>>>>>> thx for response.
>>>>>>> meanwhile,
>>>>>>> I notice that the max allowed layers is exactly 101.
>>>>>>> This mean (knowing C/C++) an array of 100 elements.
>>>>>>> Searching for this particular value,
>>>>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>>>>> is defined
>>>>>>> mDefaultMaxLayers = 100;
>>>>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>>>> if ( maxLayerEnv )
>>>>>>> So a possible solution could be to set this environment variable.
>>>>>>> I try and report.
>>>>>>> Regards,
>>>>>>> Andrea.
>>>>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>>>>> It is a problem with the layer cache. Will provide a fix for that soon.
>>>>>>>> Regards,
>>>>>>>> Marco
>>>>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>>>>> Hi,
>>>>>>>>> I confirm.
>>>>>>>>> There is a layer limit in QGIS-Server
>>>>>>>>> I do a huge test removing one by one all the layers from my project.
>>>>>>>>> And after the removing of every single layer I retest the working.
>>>>>>>>> Aftr a while of time. I reach the limit.
>>>>>>>>> And the project begin to run.
>>>>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>>>>> single
>>>>>>>>> group.
>>>>>>>>> All the test give the response that seem to be the max number of
>>>>>>>>> layers in a project.
>>>>>>>>> So the question is:
>>>>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>>>>> accepted from qgis-server.
>>>>>>>>> This not good for a WYSIWYG system.
>>>>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>>>>> problem.
>>>>>>>>> Meanwhile,
>>>>>>>>> Now the question is on what structure is this limit ?
>>>>>>>>> I don't guess it is simply a layer limit but perhaps a more specific
>>>>>>>>> structure.
>>>>>>>>> Now I have a project that crash , and a project with a one less layer
>>>>>>>>> that
>>>>>>>>> work.
>>>>>>>>> Doing a DIFF beetween the two projects I see the possible structure
>>>>>>>>> breakable are:
>>>>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>>>>> maplayer
>>>>>>>>> Digitizing -> LayerSnappingList -> value (type QStringList)
>>>>>>>>> Digitizing -> LayerSnappingEnabledList -> value (type QStringList)
>>>>>>>>> Digitizing -> LayerSnapToList -> value (type QStringList)
>>>>>>>>> Digitizing -> LayerSnappingToleranceList -> value (type QStringList)
>>>>>>>>> I check if in the code there is a limited array dimension for this
>>>>>>>>> objects.
>>>>>>>>> Regards,
>>>>>>>>> Andrea.
>>>>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>> Hi,
>>>>>>>>>> I do some other tests.
>>>>>>>>>> I take my project that give QG crash and split it in two compementary
>>>>>>>>>> projects.
>>>>>>>>>> Of course I do this using qgis desktop to avoid unvolontary errors.
>>>>>>>>>> Testing both of them on QS there is no crash !
>>>>>>>>>> So:
>>>>>>>>>> The first plausible theory I can give is that Qgis-Server has a LIMIT
>>>>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>>>>> Is this a plausible theory ?
>>>>>>>>>> Thx,
>>>>>>>>>> Andrea.
>>>>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>>>>> The qgis-server will run correctly with another project that seem
>>>>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>>>>> The project that crash my QG run correctly and smootly on a qgis
>>>>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>>>>> The project use SVG symbols, but also the other project I test on
>>>>>>>>>>> QSused SVG symbol
>>>>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>>>>> Also I update to the very last (about 4 hours ago) master version.
>>>>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>>>>> So I set an environment shell to run it manually and to test the cgi
>>>>>>>>>>> with a gdb session.
>>>>>>>>>>> The results are this:
>>>>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>>>>> Using host libthread_db library
>>>>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>>>> from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>>>>> (gdb)
>>>>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>>>>> But another project will run without any apparent problem.
>>>>>>>>>>> Many thx for every hint.
>>>>>>>>>>> Andrea Peri
>>>>>>>>>>> qwerty àèìòù
>>>>>>>>>> Andrea Peri
>>>>>>>>>> qwerty àèìòù
>>>>>>>> Dr. Marco Hugentobler
>>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Andrea Peri
>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
