[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri
aperi2007 at gmail.com
Sun Jun 22 08:50:31 PDT 2014
I guess it is not a timeout question.
To avoid the interference of the server web
I test it running into a shell (a cgi is always an executables)
I guess there is something else.
If I set the MAX_CACHE_LAYERS qgis server run and return the
getcapabilities (I ask it to test)
otherwise it crash.
My project seem to have 164 layers.
But perhaps I count wrong, because
if I set MAX_CACHE_LAYERS = 163 it run. Instead if I set =162 it crash.
2014-06-22 16:01 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> Just tried it with a project containing 111 layers here and the WMS server
> works fine for me.
> Could you check the apache error log if you are running into a server
> timeout ( fcgid module kills process after some time ).
> Marco
> On 22.06.2014 14:22, Andrea Peri wrote:
>> No,
>> sorry , my wrong.
>> The workaround MAX_CACHE_LAYERS still work.
>> A.
>> 2014-06-22 14:01 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>> Hi Marco, other information:
>>> The
>>> MAX_CACHE_LAYERS workarund
>>> Now seem do not work anymore.
>>> 2014-06-22 13:48 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>> Hi,
>>>> I tested it but don't seem work.
>>>> I'm using the master, is that ?
>>>> A.
>>>> 2014-06-22 13:04 GMT+02:00 Marco Hugentobler
>>>>> It should work now. Could you test with the current git version? My
>>>>> test
>>>>> projects are not large enough.
>>>>> Regards,
>>>>> Marco
>>>>> On 22.06.2014 12:27, Andrea Peri wrote:
>>>>>> you have right,
>>>>>> it is not a good solution. Too project depending and resource
>>>>>> consuming.
>>>>>> thx for a better fixing
>>>>>> A.
>>>>>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>>>>>> This is a short-time workaround for users.
>>>>>>> Regards,
>>>>>>> Marco
>>>>>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>>>>>> Hi,
>>>>>>>> thx for response.
>>>>>>>> meanwhile,
>>>>>>>> I notice that the max allowed layers is exactly 101.
>>>>>>>> This mean (knowing C/C++) an array of 100 elements.
>>>>>>>> Searching for this particular value,
>>>>>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>>>>>> is defined
>>>>>>>> mDefaultMaxLayers = 100;
>>>>>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>>>>> if ( maxLayerEnv )
>>>>>>>> So a possible solution could be to set this environment variable.
>>>>>>>> I try and report.
>>>>>>>> Regards,
>>>>>>>> Andrea.
>>>>>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>>>>>> It is a problem with the layer cache. Will provide a fix for that
>>>>>>>>> soon.
>>>>>>>>> Regards,
>>>>>>>>> Marco
>>>>>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I confirm.
>>>>>>>>>> There is a layer limit in QGIS-Server
>>>>>>>>>> I do a huge test removing one by one all the layers from my
>>>>>>>>>> project.
>>>>>>>>>> And after the removing of every single layer I retest the working.
>>>>>>>>>> Aftr a while of time. I reach the limit.
>>>>>>>>>> And the project begin to run.
>>>>>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>>>>>> single
>>>>>>>>>> group.
>>>>>>>>>> All the test give the response that seem to be the max number of
>>>>>>>>>> layers in a project.
>>>>>>>>>> So the question is:
>>>>>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>>>>>> accepted from qgis-server.
>>>>>>>>>> This not good for a WYSIWYG system.
>>>>>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>>>>>> problem.
>>>>>>>>>> Meanwhile,
>>>>>>>>>> Now the question is on what structure is this limit ?
>>>>>>>>>> I don't guess it is simply a layer limit but perhaps a more
>>>>>>>>>> specific
>>>>>>>>>> structure.
>>>>>>>>>> Now I have a project that crash , and a project with a one less
>>>>>>>>>> layer
>>>>>>>>>> that
>>>>>>>>>> work.
>>>>>>>>>> Doing a DIFF beetween the two projects I see the possible
>>>>>>>>>> structure
>>>>>>>>>> breakable are:
>>>>>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>>>>>> maplayer
>>>>>>>>>> Digitizing -> LayerSnappingList -> value (type QStringList)
>>>>>>>>>> Digitizing -> LayerSnappingEnabledList -> value (type
>>>>>>>>>> QStringList)
>>>>>>>>>> Digitizing -> LayerSnapToList -> value (type QStringList)
>>>>>>>>>> Digitizing -> LayerSnappingToleranceList -> value (type
>>>>>>>>>> QStringList)
>>>>>>>>>> I check if in the code there is a limited array dimension for this
>>>>>>>>>> objects.
>>>>>>>>>> Regards,
>>>>>>>>>> Andrea.
>>>>>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I do some other tests.
>>>>>>>>>>> I take my project that give QG crash and split it in two
>>>>>>>>>>> compementary
>>>>>>>>>>> projects.
>>>>>>>>>>> Of course I do this using qgis desktop to avoid unvolontary
>>>>>>>>>>> errors.
>>>>>>>>>>> Testing both of them on QS there is no crash !
>>>>>>>>>>> So:
>>>>>>>>>>> The first plausible theory I can give is that Qgis-Server has a
>>>>>>>>>>> LIMIT
>>>>>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>>>>>> Is this a plausible theory ?
>>>>>>>>>>> Thx,
>>>>>>>>>>> Andrea.
>>>>>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>>>>>> The qgis-server will run correctly with another project that
>>>>>>>>>>>> seem
>>>>>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>>>>>> The project that crash my QG run correctly and smootly on a
>>>>>>>>>>>> qgis
>>>>>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>>>>>> The project use SVG symbols, but also the other project I test
>>>>>>>>>>>> on
>>>>>>>>>>>> QSused SVG symbol
>>>>>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>>>>>> Also I update to the very last (about 4 hours ago) master
>>>>>>>>>>>> version.
>>>>>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>>>>>> So I set an environment shell to run it manually and to test the
>>>>>>>>>>>> cgi
>>>>>>>>>>>> with a gdb session.
>>>>>>>>>>>> The results are this:
>>>>>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>>>>>> Using host libthread_db library
>>>>>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>>>>> from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>>>>>> (gdb)
>>>>>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>>>>>> But another project will run without any apparent problem.
>>>>>>>>>>>> Many thx for every hint.
>>>>>>>>>>>> Andrea Peri
>>>>>>>>>>>> qwerty àèìòù
>>>>>>>>>>> Andrea Peri
>>>>>>>>>>> qwerty àèìòù
>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-developer mailing list
>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Andrea Peri
>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
