[Qgis-developer] qgis-server will crash on a specific project
    Andrea Peri
    aperi2007 at gmail.com
    Sun Jun 22 09:11:30 PDT 2014
Hi Marco,
I apologize,
my wrong.
I wrong to substitute the new master .
Now do it correctly and the crash is disappeared.
You patch is ok.
Andrea.
2014-06-22 17:50 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> I guess it is not a timeout question.
> To avoid the interference of the server web
> I test it running into a shell (a cgi is always an executables)
> I guess there is something else.
> If I set the MAX_CACHE_LAYERS qgis server run and return the
> getcapabilities (I ask it to test)
> otherwise it crash.
> My project seem to have 164 layers.
> But perhaps I count wrong, because
> if I set MAX_CACHE_LAYERS = 163 it run. Instead if I set =162 it crash.
> 2014-06-22 16:01 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>> Just tried it with a project containing 111 layers here and the WMS server
>> works fine for me.
>> Could you check the apache error log if you are running into a server
>> timeout ( fcgid module kills process after some time ).
>> Marco
>> On 22.06.2014 14:22, Andrea Peri wrote:
>>> No,
>>> sorry , my wrong.
>>> The workaround MAX_CACHE_LAYERS still work.
>>> A.
>>> 2014-06-22 14:01 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>> Hi Marco, other information:
>>>> The
>>>> MAX_CACHE_LAYERS workarund
>>>> Now seem do not work anymore.
>>>> 2014-06-22 13:48 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>> Hi,
>>>>> I tested it but don't seem work.
>>>>> I'm using the master, is that ?
>>>>> A.
>>>>> 2014-06-22 13:04 GMT+02:00 Marco Hugentobler
>>>>>> It should work now. Could you test with the current git version? My
>>>>>> test
>>>>>> projects are not large enough.
>>>>>> Regards,
>>>>>> Marco
>>>>>> On 22.06.2014 12:27, Andrea Peri wrote:
>>>>>>> you have right,
>>>>>>> it is not a good solution. Too project depending and resource
>>>>>>> consuming.
>>>>>>> thx for a better fixing
>>>>>>> A.
>>>>>>> 2014-06-22 12:15 GMT+02:00 Marco Hugentobler
>>>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" )
>>>>>>>> This is a short-time workaround for users.
>>>>>>>> Regards,
>>>>>>>> Marco
>>>>>>>> On 22.06.2014 12:12, Andrea Peri wrote:
>>>>>>>>> Hi,
>>>>>>>>> thx for response.
>>>>>>>>> meanwhile,
>>>>>>>>> I notice that the max allowed layers is exactly 101.
>>>>>>>>> This mean (knowing C/C++) an array of 100 elements.
>>>>>>>>> Searching for this particular value,
>>>>>>>>> i find in the file "mapserver/qgsmslayercache.cpp"
>>>>>>>>> is defined
>>>>>>>>>            mDefaultMaxLayers = 100;
>>>>>>>>> if not defined the environment variable "MAX_CACHE_LAYERS"
>>>>>>>>> char* maxLayerEnv = getenv( "MAX_CACHE_LAYERS" );
>>>>>>>>>      if ( maxLayerEnv )
>>>>>>>>> So a possible solution could be to set this environment variable.
>>>>>>>>> I try and report.
>>>>>>>>> Regards,
>>>>>>>>> Andrea.
>>>>>>>>> 2014-06-22 12:07 GMT+02:00 Marco Hugentobler
>>>>>>>>>> It is a problem with the layer cache. Will provide a fix for that
>>>>>>>>>> soon.
>>>>>>>>>> Regards,
>>>>>>>>>> Marco
>>>>>>>>>> On 22.06.2014 11:49, Andrea Peri wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> I confirm.
>>>>>>>>>>> There is a layer limit in QGIS-Server
>>>>>>>>>>> I do a huge test removing one by one all the layers from my
>>>>>>>>>>> project.
>>>>>>>>>>> And after the removing of every single layer I retest the working.
>>>>>>>>>>> Aftr a while of time. I reach the limit.
>>>>>>>>>>> And the project begin to run.
>>>>>>>>>>> I do other test to exclude that was the number of layer inside a
>>>>>>>>>>> single
>>>>>>>>>>> group.
>>>>>>>>>>> All the test give the response that seem to be the max number of
>>>>>>>>>>> layers in a project.
>>>>>>>>>>> So the question is:
>>>>>>>>>>> QGIS desktop allow to put more layers rather than how many are
>>>>>>>>>>> accepted from qgis-server.
>>>>>>>>>>> This not good for a WYSIWYG system.
>>>>>>>>>>> Ok, I will try to patch my server when found exactly where is the
>>>>>>>>>>> problem.
>>>>>>>>>>> Meanwhile,
>>>>>>>>>>> Now the question is on what structure is this limit ?
>>>>>>>>>>> I don't guess it is simply a layer limit but perhaps a more
>>>>>>>>>>> specific
>>>>>>>>>>> structure.
>>>>>>>>>>> Now I have a project that crash , and a project with a one less
>>>>>>>>>>> layer
>>>>>>>>>>> that
>>>>>>>>>>> work.
>>>>>>>>>>> Doing a DIFF beetween the two projects I see the possible
>>>>>>>>>>> structure
>>>>>>>>>>> breakable are:
>>>>>>>>>>> layer-tree-canvas -> custom-order -> item
>>>>>>>>>>> maplayer
>>>>>>>>>>> Digitizing -> LayerSnappingList -> value   (type QStringList)
>>>>>>>>>>> Digitizing -> LayerSnappingEnabledList -> value   (type
>>>>>>>>>>> QStringList)
>>>>>>>>>>> Digitizing -> LayerSnapToList -> value   (type QStringList)
>>>>>>>>>>> Digitizing -> LayerSnappingToleranceList -> value   (type
>>>>>>>>>>> QStringList)
>>>>>>>>>>> I check if in the code there is a limited array dimension for this
>>>>>>>>>>> objects.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Andrea.
>>>>>>>>>>> 2014-06-22 7:29 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I do some other tests.
>>>>>>>>>>>> I take my project that give QG crash and split it in two
>>>>>>>>>>>> compementary
>>>>>>>>>>>> projects.
>>>>>>>>>>>> Of course I do this using qgis desktop to avoid unvolontary
>>>>>>>>>>>> errors.
>>>>>>>>>>>> Testing both of them on QS there is no crash !
>>>>>>>>>>>> So:
>>>>>>>>>>>> The first plausible theory I can give is that Qgis-Server has a
>>>>>>>>>>>> LIMIT
>>>>>>>>>>>> to the number of Groups or Layers it can have in a project.
>>>>>>>>>>>> A limit different (and less) than qgis desktop (osgeo4w version).
>>>>>>>>>>>> Is this a plausible theory ?
>>>>>>>>>>>> Thx,
>>>>>>>>>>>> Andrea.
>>>>>>>>>>>> 2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> I have a qgis-server that will crash on a specific project.
>>>>>>>>>>>>> The qgis-server will run correctly with another project that
>>>>>>>>>>>>> seem
>>>>>>>>>>>>> almost similar (both use the SVG symbols).
>>>>>>>>>>>>> The project that crash my QG  run correctly and smootly on a
>>>>>>>>>>>>> qgis
>>>>>>>>>>>>> desktop (qgis-dev) on a windows system.
>>>>>>>>>>>>> The project use SVG symbols, but also the other project I test
>>>>>>>>>>>>> on
>>>>>>>>>>>>> QSused SVG symbol
>>>>>>>>>>>>> so I suppose the SVG engine is ok.
>>>>>>>>>>>>> Also I check t have set correctly the SVG paths.
>>>>>>>>>>>>> Also I update to the very last (about 4 hours ago) master
>>>>>>>>>>>>> version.
>>>>>>>>>>>>> After all this check the qgis-server still crash.
>>>>>>>>>>>>> So I try to set the logfile, but the log is always empty.
>>>>>>>>>>>>> This mean that the cgi qgis-server will crash almost immediatly.
>>>>>>>>>>>>> So I set an environment shell to run it manually and to test the
>>>>>>>>>>>>> cgi
>>>>>>>>>>>>> with a gdb session.
>>>>>>>>>>>>> The results are this:
>>>>>>>>>>>>> [Thread debugging using libthread_db enabled]
>>>>>>>>>>>>> Using host libthread_db library
>>>>>>>>>>>>> "/lib/x86_64-linux-gnu/libthread_db.so.1".
>>>>>>>>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>>>>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>>>>>>>>> [New Thread 0x7fffe307c700 (LWP 1844)]
>>>>>>>>>>>>> [New Thread 0x7fffe27ea700 (LWP 1845)]
>>>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>>>> 0x00007ffff4fc06da in qHash(QString const&) ()
>>>>>>>>>>>>>        from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
>>>>>>>>>>>>> (gdb)
>>>>>>>>>>>>> The version of libQtCore.so.4 I run on the linux is 4.8.2.
>>>>>>>>>>>>> Perhaps the 4.8.2 is too old for qgis-server ?
>>>>>>>>>>>>> But another project will run without any apparent problem.
>>>>>>>>>>>>> Many thx for every hint.
>>>>>>>>>>>>> Andrea Peri
>>>>>>>>>>>>> qwerty àèìòù
>>>>>>>>>>>> Andrea Peri
>>>>>>>>>>>> qwerty àèìòù
>>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>>> Andrea Peri
>>>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
