[Qgis-developer] Simplify geometry affects $area calculations
Martin Dobias wonder.sk at gmail.com
Mon Jun 23 00:25:23 PDT 2014
On Mon, Jun 23, 2014 at 1:59 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi,
> As far as I can remember from reviewing the code, server side
> simplification is enabled on a per-request basis. So it should be
> possible to disable it when certain parameters (like $area required)
> are met.
Right. Another good piece of news is that when doing feature requests
with API, simplification must be explicitly turned on - so it does not
affect code that does not expect simplification.
Regards
Martin
