[Qgis-developer] Simplify geometry affects $area calculations
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Jun 23 00:29:25 PDT 2014
My assumption is, that in this particular case the geometry is used in
the rendering process (hence a simplified version).
It could be checked if an expression used in the rendering process
requires the geometry (or $area and maybe others?) just the way
attributes are only requested for rendering if they are used in an
expression.
