[Qgis-developer] Simplify geometry affects $area calculations
Anita Graser
anitagraser at gmx.at
Mon Jun 23 11:31:37 PDT 2014
On Mon, Jun 23, 2014 at 9:29 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> My assumption is, that in this particular case the geometry is used in
> the rendering process (hence a simplified version).
> It could be checked if an expression used in the rendering process
> requires the geometry (or $area and maybe others?) just the way
> attributes are only requested for rendering if they are used in an
> expression.
That sounds like the behavior I would expect. Should I open a ticket for this?
Best wishes,
Anita
