[Qgis-developer] QGIS Crash - Serious problem in 2x
Richard Duivenvoorde rdmailings at duif.net
Mon Jun 23 23:29:37 PDT 2014
Hi Ted,
I'm not on Win, but if possible can you test this with latest release
candidates, see
http://qgis.org/en/site/getinvolved/development/index.html#location-of-prereleases-nightly-builds
and if that one is crashing, please file an issue:
http://qgis.org/en/site/getinvolved/development/index.html#bugs-features-and-issues
Current dev version has a lot of changes under the hood, but also an
awfull lot of fixes!
So please test the latest version and let us know if that crashes also
Regards,
On 24-06-14 01:30, Ted wrote:
> forgot,
> using Windows OS
> Win 7 Professional x64
> Thanks
> Ted
> On Tue, Jun 24, 2014 at 7:27 AM, Ted <tiruchirapalli at gmail.com
> <mailto:tiruchirapalli at gmail.com>> wrote:
>     Hi Developers
>     Encountered a very serious problem, looks like this issue is there
>     in 2.x
>     Ways to reproduce;
>     1. Add a world boundary shp file in wgs84 (you can use other files too)
>     http://thematicmapping.org/downloads/world_borders.php
>     2. Open the print composer, add a new map
>     3. add scale bar
>     4. close the composer, return back
>     5 remove the layer from layer list
>     6. boom, qgis crash
>     hope you can fix this soon, thanks
>     The scale bar issue
>     1. When a file is degree (wgs84), the scale-bar in print composer is
>     useless since its trying to use the map unit.
>     2. Its logical that, in map composer its always linear map unit as
>     in meter, feet, km, etc
>     3. using qgis in schools and this pose a serious issue, since the
>     users dont understand projection etc.
>     4. the expected behavior is, immaterial of underlying projection the
>     scale-bar should have the option to use linear map unit, specially
>     meters, km, mile
>     5. read in stackexchange, this is a known issue. hope the dev
>     community can help to fix this one.
>     thanks a lot.
>     hurt my fingers, not able to type proper :(
>     cheers
>     ted
> Qgis-developer mailing list
