[Qgis-developer] QGIS Crash - Serious problem in 2x
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Jun 23 23:59:21 PDT 2014
Hi Ted,
I don't get a crash here (Linux/latest prerelease). It would be much
appreciated if you could follow Richards advice for testing/reporting.
Concerning the scale-bar issue. I think, that one should always be
allowed to show a scale-bar, but that the units need to match with the
one in the projection, so in the case of WGS84, the units should be degrees.
Regards,
Matthias
On 24.06.2014 08:29, Richard Duivenvoorde wrote:
> Hi Ted,
> I'm not on Win, but if possible can you test this with latest release
> candidates, see
> http://qgis.org/en/site/getinvolved/development/index.html#location-of-prereleases-nightly-builds
> and if that one is crashing, please file an issue:
> http://qgis.org/en/site/getinvolved/development/index.html#bugs-features-and-issues
> Current dev version has a lot of changes under the hood, but also an
> awfull lot of fixes!
> So please test the latest version and let us know if that crashes also
> Regards,
> On 24-06-14 01:30, Ted wrote:
>> forgot,
>> using Windows OS
>> Win 7 Professional x64
>> Thanks
>> Ted
>> On Tue, Jun 24, 2014 at 7:27 AM, Ted <tiruchirapalli at gmail.com
>> <mailto:tiruchirapalli at gmail.com>> wrote:
>> Hi Developers
>> Encountered a very serious problem, looks like this issue is there
>> in 2.x
>> Ways to reproduce;
>> 1. Add a world boundary shp file in wgs84 (you can use other files too)
>> http://thematicmapping.org/downloads/world_borders.php
>> 2. Open the print composer, add a new map
>> 3. add scale bar
>> 4. close the composer, return back
>> 5 remove the layer from layer list
>> 6. boom, qgis crash
>> hope you can fix this soon, thanks
>> The scale bar issue
>> 1. When a file is degree (wgs84), the scale-bar in print composer is
>> useless since its trying to use the map unit.
>> 2. Its logical that, in map composer its always linear map unit as
>> in meter, feet, km, etc
>> 3. using qgis in schools and this pose a serious issue, since the
>> users dont understand projection etc.
>> 4. the expected behavior is, immaterial of underlying projection the
>> scale-bar should have the option to use linear map unit, specially
>> meters, km, mile
>> 5. read in stackexchange, this is a known issue. hope the dev
>> community can help to fix this one.
>> thanks a lot.
>> hurt my fingers, not able to type proper :(
>> cheers
>> ted
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
