[Qgis-developer] QGIS Crash - Serious problem in 2x
    Jorge Tornero - Listas
    jtorlistas at gmail.com
    Tue Jun 24 01:07:53 PDT 2014
Hi, Ted, Matthias and all,
If you enable CRS transform on-the-fly, meter/feet/NM scales can be
shown in WGS84 projects.
About what Matthias said in
> Concerning the scale-bar issue. I think, that one should always be
> allowed to show a scale-bar, but that the units need to match with the
> one in the projection, so in the case of WGS84, the units should be degrees.
In my opinion, despite this is completely true from a formal point of
view, sometimes you need scales in 'real world' units just to make
possible for people to understand your maps. For the most of the people
I know that see my little work it makes no sense a scale in degrees (in
fact, they could have it in the grid labels) but a scale in nautical
miles (or whatever) makes sense inmediatly for them, even if it is not
accurate. So, providing that the person who is making the map should
know what he/she is doing, it is nice for the user to have the
possibility to show the scale in whatever units he wants. Maybe it could
be corrected just using a projection (I guess that's the proper way),
but sometimes it leads to "weird" (in the sense of people is used to see
*their geography* in a determinate way) maps which somehow annoy people.
All the best,
Jorge Tornero
El 24/06/14 08:59, Matthias Kuhn escribió:
> Hi Ted,
> I don't get a crash here (Linux/latest prerelease). It would be much
> appreciated if you could follow Richards advice for testing/reporting.
> Regards,
> Matthias
> On 24.06.2014 08:29, Richard Duivenvoorde wrote:
>> Hi Ted,
>> I'm not on Win, but if possible can you test this with latest release
>> candidates, see
>> http://qgis.org/en/site/getinvolved/development/index.html#location-of-prereleases-nightly-builds
>> and if that one is crashing, please file an issue:
>> http://qgis.org/en/site/getinvolved/development/index.html#bugs-features-and-issues
>> Current dev version has a lot of changes under the hood, but also an
>> awfull lot of fixes!
>> So please test the latest version and let us know if that crashes also
>> Regards,
>> On 24-06-14 01:30, Ted wrote:
>>> forgot,
>>> using Windows OS
>>> Win 7 Professional x64
>>> Thanks
>>> Ted
>>> On Tue, Jun 24, 2014 at 7:27 AM, Ted <tiruchirapalli at gmail.com
>>> <mailto:tiruchirapalli at gmail.com>> wrote:
>>>      Hi Developers
>>>      Encountered a very serious problem, looks like this issue is there
>>>      in 2.x
>>>      Ways to reproduce;
>>>      1. Add a world boundary shp file in wgs84 (you can use other files too)
>>>      http://thematicmapping.org/downloads/world_borders.php
>>>      2. Open the print composer, add a new map
>>>      3. add scale bar
>>>      4. close the composer, return back
>>>      5 remove the layer from layer list
>>>      6. boom, qgis crash
>>>      hope you can fix this soon, thanks
>>>      The scale bar issue
>>>      1. When a file is degree (wgs84), the scale-bar in print composer is
>>>      useless since its trying to use the map unit.
>>>      2. Its logical that, in map composer its always linear map unit as
>>>      in meter, feet, km, etc
>>>      3. using qgis in schools and this pose a serious issue, since the
>>>      users dont understand projection etc.
>>>      4. the expected behavior is, immaterial of underlying projection the
>>>      scale-bar should have the option to use linear map unit, specially
>>>      meters, km, mile
>>>      5. read in stackexchange, this is a known issue. hope the dev
>>>      community can help to fix this one.
>>>      thanks a lot.
>>>      hurt my fingers, not able to type proper :(
>>>      cheers
>>>      ted
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
