[Qgis-developer] QGIS Crash - Serious problem in 2x
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Jun 24 01:24:35 PDT 2014
IMHO a scale bar in degrees doesn't make sense at all apart from being
unused to readers of the map. Because one degree in latitude is always
(uhmm if I recall correctly) 110 km, in longitude this is only true for
the equator, the closer you get to the poles the less km per degree in
longitude (until 0 at the pole itself). If you display only a small part
of the earth you migth manage with two scale bars (lon/lat) but how
would you imagine a scale bar for e.g. north America?
Bernhard
Am 24.06.2014 10:07, schrieb Jorge Tornero - Listas:
> Hi, Ted, Matthias and all,
> If you enable CRS transform on-the-fly, meter/feet/NM scales can be
> shown in WGS84 projects.
> About what Matthias said in
>> Concerning the scale-bar issue. I think, that one should always be
>> allowed to show a scale-bar, but that the units need to match with the
>> one in the projection, so in the case of WGS84, the units should be
>> degrees.
> In my opinion, despite this is completely true from a formal point of
> view, sometimes you need scales in 'real world' units just to make
> possible for people to understand your maps. For the most of the people
> I know that see my little work it makes no sense a scale in degrees (in
> fact, they could have it in the grid labels) but a scale in nautical
> miles (or whatever) makes sense inmediatly for them, even if it is not
> accurate. So, providing that the person who is making the map should
> know what he/she is doing, it is nice for the user to have the
> possibility to show the scale in whatever units he wants. Maybe it could
> be corrected just using a projection (I guess that's the proper way),
> but sometimes it leads to "weird" (in the sense of people is used to see
> *their geography* in a determinate way) maps which somehow annoy people.
> All the best,
> Jorge Tornero
> El 24/06/14 08:59, Matthias Kuhn escribió:
>> Hi Ted,
>> I don't get a crash here (Linux/latest prerelease). It would be much
>> appreciated if you could follow Richards advice for testing/reporting.
>> degrees.
>> Regards,
>> Matthias
>> On 24.06.2014 08:29, Richard Duivenvoorde wrote:
>>> Hi Ted,
>>> I'm not on Win, but if possible can you test this with latest release
>>> candidates, see
>>> http://qgis.org/en/site/getinvolved/development/index.html#location-of-prereleases-nightly-builds
>>> and if that one is crashing, please file an issue:
>>> http://qgis.org/en/site/getinvolved/development/index.html#bugs-features-and-issues
>>> Current dev version has a lot of changes under the hood, but also an
>>> awfull lot of fixes!
>>> So please test the latest version and let us know if that crashes also
>>> Regards,
>>> On 24-06-14 01:30, Ted wrote:
>>>> forgot,
>>>> using Windows OS
>>>> Win 7 Professional x64
>>>> Thanks
>>>> Ted
>>>> On Tue, Jun 24, 2014 at 7:27 AM, Ted <tiruchirapalli at gmail.com
>>>> <mailto:tiruchirapalli at gmail.com>> wrote:
>>>> Hi Developers
>>>> Encountered a very serious problem, looks like this issue is there
>>>> in 2.x
>>>> Ways to reproduce;
>>>> 1. Add a world boundary shp file in wgs84 (you can use other
>>>> files too)
>>>> http://thematicmapping.org/downloads/world_borders.php
>>>> 2. Open the print composer, add a new map
>>>> 3. add scale bar
>>>> 4. close the composer, return back
>>>> 5 remove the layer from layer list
>>>> 6. boom, qgis crash
>>>> hope you can fix this soon, thanks
>>>> The scale bar issue
>>>> 1. When a file is degree (wgs84), the scale-bar in print
>>>> composer is
>>>> useless since its trying to use the map unit.
>>>> 2. Its logical that, in map composer its always linear map unit as
>>>> in meter, feet, km, etc
>>>> 3. using qgis in schools and this pose a serious issue, since the
>>>> users dont understand projection etc.
>>>> 4. the expected behavior is, immaterial of underlying
>>>> projection the
>>>> scale-bar should have the option to use linear map unit, specially
>>>> meters, km, mile
>>>> 5. read in stackexchange, this is a known issue. hope the dev
>>>> community can help to fix this one.
>>>> thanks a lot.
>>>> hurt my fingers, not able to type proper :(
>>>> cheers
>>>> ted
__________ Information from ESET Mail Security, version of virus signature database 9990 (20140624) __________
The message was checked by ESET Mail Security.
http://www.eset.com
