[Qgis-developer] qgis-server and troubles using jpeg as output format
Larry Shaffer
larrys at dakotacarto.com
Tue Jun 24 16:30:31 PDT 2014
Hi Andrea,
On Tue, Jun 24, 2014 at 3:21 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi Larry,
> thx for hints,
> I never suppose the jpeg was due to a plugin.
> I check the existence of libjpeg, but never seen for a plugin folder
> because I'm running only the qgis-server without any desktop
> capability.
> Now searching for this plugin folder,
> effectively I see a broken symbolic link in the
> /usr/share/qt4/plugins forward a ../../lib/qt4/plugins
> It seem like if I'm not install something....
Not sure what might be missing (or what Debian and Qt versions you are
using), but it seems the image format plugins are part of the QtGui package
install [0].
[0] https://packages.debian.org/wheezy/amd64/libqtgui4/filelist
Regards,
Larry
> I choose to install many libs from debian repos
> also these two:
> pyqt4-dev-tools, python-qt4-dev
> Perhaps I miss something other lib,
> but I guess this should be report by the cmake routines.
> Perhaps a missing check in the cmake ?
> Now I need to understand what library is missing.
> Unfortunately I'm not so skill with qt libs.
> there is somewhere a list of all the need libraries ?
> Thx,
> Andrea.
> 2014-06-24 21:46 GMT+02:00 Larry Shaffer <larrys at dakotacarto.com>:
> > Hi Andrea,
> > It sounds to me like your Qt, when loaded by qgis_mapserv.fcgi, is not
> > correctly finding the 'plugins' directory, specifically its
> 'imageformats'
> > subdirectory. If that machine also runs QGIS Desktop, you can verify
> your Qt
> > install has the image plugins by launching QGIS and checking the
> Providers
> > section in the About QGIS dialog.
> > Since Qt has native, built-in support for PNG, it should always be able
> to
> > render a WMS request to PNG. If Qt can not load the Qt JPEG image format
> > plugin, then JPEG will not be rendered.
> > Just guessing, but you may try setting the env variable QT_PLUGIN_PATH in
> > the FCGI environment to help Qt find the plugins directory [0]. If the
> > imageformats subdirectory is missing some plugins, then there is
> something
> > funky/missing with your Qt install.
> > [0] http://qt-project.org/doc/qt-4.8/deployment-plugins.html
> > Regards,
> > Larry
> > On Tue, Jun 24, 2014 at 7:26 AM, Andrea Peri <aperi2007 at gmail.com>
> wrote:
> >> Hi,
> >> I do some tests.
> >> Using a shell environment to see any error returned.
> >> I see using the
> >> "FORMAT=image/png"
> >> the image is correctly returned.
> >> Instead using the
> >> "FORMAT=image/jpeg"
> >> the image is not returned.
> >> But no crash at all.
> >> Simply the qgis-server request will end returning nothing.
> >> Also using a debug session no error reported.
> >> Only apparently return nothing.
> >> A.
> >> 2014-06-24 14:31 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> >> > Hi,
> >> > I'm having some trouble with qgis-server and the output in jpeg
> format.
> >> > The request getmap using the jpeg format as not response at all.
> >> > I try on two distinct debian machine but the result is the same.
> >> > So I guess the most probable theory is the lack of a library or a
> >> > library too early on Debian stable distro'.
> >> > So I like to know what is the used jpeg library and if there is a
> >> > minimal version for the jpeg library used.
> >> > Thx
> >> > Andrea Peri
> >> > qwerty àèìòù
> >> Andrea Peri
> >> qwerty àèìòù
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140624/3ab13730/attachment-0001.html>
