[Qgis-developer] 2.2 project keeps crashing after load
Andreas Neumann
a.neumann at carto.net
Wed Jun 25 03:04:06 PDT 2014
Hi again,
Just before the crash I see the following messages in the log window:
"QPixmap: It is not safe to use pixmaps outside the GUI thread"
same message repeated several times.
Does this ring any bell with someone?
Thanks,
Andreas
Am 25.06.2014 09:55, schrieb Andreas Neumann:
> Hi,
> I have some related questions regarding my crash:
> * What software are people using to analyze the minidump file?
> * During the QGIS crash I see that there are 570 messages in the log
> window - but because QGIS crashes I cannot access these log-messages
> anymore. Are these log-messages also available somewhere in a file so I
> can read them?
> The other thing I found out is that I can open the project if another
> project was loaded before. But if I open the project from an empty QGIS
> session it crashes. This behaviour is consistent. It always crashes when
> it opens as the first project and always works when another project was
> loaded before. Very strange ...
> Andreas
> Am 25.06.2014 09:35, schrieb Andreas Neumann:
>> Hi,
>> I have a 2.2 project that keeps crashing immediately after load - so not
>> much chance to investigate. The project has some PostgreSQL and a WMS
>> layer. Testing the last nightly on Win 64 bit build.
>> Can qgis-devs read something in the minidump file to give me a hint what
>> may cause the crash?
>> The minidump is available at
>> http://webgis.uster.ch/temp/qgis-20140625-112518-1784-4568-39eaff9.dmp
>> I have no idea what is wrong with this project. It is a rather simple
>> project compared to others.
>> Thank you for your help,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
