[Qgis-developer] 2.2 project keeps crashing after load
Andreas Neumann
a.neumann at carto.net
Wed Jun 25 04:13:52 PDT 2014
Yes - the .qgs file is here:
http://webgis.uster.ch/temp/administrative_grenzen.zip
I changed the credentials of the Postgis connection. The project
contains 5 Postgis layers and 1 WMS layer.
Thank you for having a look at it.
Andreas
Am 25.06.2014 10:18, schrieb Nyall Dawson:
>>> Am 25.06.2014 09:35, schrieb Andreas Neumann:
>>>> I have a 2.2 project that keeps crashing immediately after load - so not
>>>> much chance to investigate. The project has some PostgreSQL and a WMS
>>>> layer. Testing the last nightly on Win 64 bit build.
> Hi Andreas,
> Can you share the project? Even without the referenced data this would help.
> Thanks,
> Nyall
