[Qgis-developer] 2.2 project keeps crashing after load
Martin Dobias
wonder.sk at gmail.com
Wed Jun 25 04:19:16 PDT 2014
Hi Andreas
On Wed, Jun 25, 2014 at 5:04 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi again,
> Just before the crash I see the following messages in the log window:
> "QPixmap: It is not safe to use pixmaps outside the GUI thread"
> same message repeated several times.
> Does this ring any bell with someone?
It may be somehow linked to MTR, but I would need more info to track
down the problem. I haven't really managed to read anything useful
from minidump files yet - I would be happy to learn from others if
they can.
Andreas, could you experiment with the project file (in 2.2) a bit to
track down the source of the problem? E.g.:
- will it crash if you remove the WMS layer?
- will it crash if you remove composers?
I have just tried your project file on Linux/64 and I get no crash
(the Postgis layers get removed on load due to missing credentials).
Regards
Martin
