[Qgis-developer] 2.2 project keeps crashing after load
Andreas Neumann
a.neumann at carto.net
Wed Jun 25 04:51:44 PDT 2014
I believe it has to do with layers that have automated labeling on
polygon layers with free or horizontal label placement algorithm.
If I turn off these layers the crashes do not appear. I can then later
turn on the visibility of these layers and it will work fine.
I will try to create a test project with the same labeling settings and
the data in an sqlite db for testing.
When QGIS crashes, I always get the "QPixmap: it is not safe to use
pixmaps outside the GUI thread" message.
Andreas
Am 25.06.2014 11:19, schrieb Martin Dobias:
> Hi Andreas
> On Wed, Jun 25, 2014 at 5:04 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi again,
>> Just before the crash I see the following messages in the log window:
>> "QPixmap: It is not safe to use pixmaps outside the GUI thread"
>> same message repeated several times.
>> Does this ring any bell with someone?
> It may be somehow linked to MTR, but I would need more info to track
> down the problem. I haven't really managed to read anything useful
> from minidump files yet - I would be happy to learn from others if
> they can.
> Andreas, could you experiment with the project file (in 2.2) a bit to
> track down the source of the problem? E.g.:
> - will it crash if you remove the WMS layer?
> - will it crash if you remove composers?
> I have just tried your project file on Linux/64 and I get no crash
> (the Postgis layers get removed on load due to missing credentials).
> Regards
> Martin
