[Qgis-developer] 2.2 project keeps crashing after load
Andreas Neumann
a.neumann at carto.net
Wed Jun 25 06:25:07 PDT 2014
I can only reproduce the issue on Windows (Win7 64bit). It does not
appear on Linux 64bit. Also on Windows it does not happen always, but often.
I have removed all composers, so this is definitely not a composer issue.
I also removed the WMS and it still crashes.
It happens with both PostgreSQL and SQLite as a datasource. It does not
happen with shapefiles as a datasource.
My project is here to download with SpatiaLite 4 as a datasource:
http://webgis.uster.ch/temp/qgis_crashing_project.zip
If someone on Windows could give it a try. It does not crash always, but
often.
Andreas
Am 25.06.2014 11:19, schrieb Martin Dobias:
> Hi Andreas
> On Wed, Jun 25, 2014 at 5:04 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi again,
>> Just before the crash I see the following messages in the log window:
>> "QPixmap: It is not safe to use pixmaps outside the GUI thread"
>> same message repeated several times.
>> Does this ring any bell with someone?
> It may be somehow linked to MTR, but I would need more info to track
> down the problem. I haven't really managed to read anything useful
> from minidump files yet - I would be happy to learn from others if
> they can.
> Andreas, could you experiment with the project file (in 2.2) a bit to
> track down the source of the problem? E.g.:
> - will it crash if you remove the WMS layer?
> - will it crash if you remove composers?
> I have just tried your project file on Linux/64 and I get no crash
> (the Postgis layers get removed on load due to missing credentials).
> Regards
> Martin
