[Qgis-developer] SOSI support in QGIS
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Jun 26 12:04:42 PDT 2014
Hi again,
Now I rebuilt the 32-bit package based on GDAL 1.11.0 which is the GDAL version QGIS is build against (the old package on OSGeo4W was built against GDAL 1.10) and tested in QGIS 2.3 (QGIS code revision 39eaff9).
The problem is now the same, James described for the 64bit version. However, ogrinfo gives no error messages and displays the content of the SOSI file and all layers just fine. So maybe it is not only a packaging issue?
James, what does your 64bit ogrinfo say when run with your SOSI file? And does ogr2ogr work for you in 64bit?
Cheers
Stefan
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Stott, James
Sent: 26. juni 2014 11:14
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] SOSI support in QGIS
Hi all,
Just wondered if anything more has happened with this?
As it stands, I get an option for SOSI files in the file open dialog of 64 bit master, but not 32 bit. (SOSI is the data standard in Norway for those that don't know).
In 64 bit, when I select a file for opening, it comes up with another dialog (similar to when you open up a gpx file) where you choose the geometry you want to load from the file. After I have selected what I want and push ok, I just get an error message saying that the data is not a valid data source.
This happens on both mine and a colleagues machine. Does this affect others too?
I have also installed the gdal-sosi package in osgeo4w. I am using Windows 7 64 Bit, osgeo4w for install. Current QGIS version is d4b07a.
If SOSI files do not open in QGIS, we should remove the option from the open file dialog window. Otherwise I think people here in Norway will have a bad experience with QGIS and SOSI.
Regards,
James Stott
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140626/f084fe27/attachment.html>
