[Qgis-developer] SOSI support in QGIS
Larry Shaffer
larrys at dakotacarto.com
Thu Jun 26 08:42:05 PDT 2014
On Thu, Jun 26, 2014 at 7:04 AM, Stott, James <fmrojst at fylkesmannen.no>
wrote:
> Hei Stefan,
> Thanks for looking at this again.
> Do you know why the SOSI option doesn’t appear in 32 bit version?
> With the release of 2.4 a day or so away, I wonder if its best to just
> remove the SOSI option from the file dialog box for the 2.4 release? That
> way people won’t be under the impression that QGIS can open SOSI when it
> can’t?
Are you sure it is specifically QGIS that can't open the file? Have you
tried GDAL directly. If there are problems with GDAL on your platform for
SOSI, but it works on others, I don't see how this should limit what is an
available feature in QGIS. It would then require fixing GDAL, or its
packaging, in this regard.
Please verify.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> Don’t know if anyone else agrees?
> James
> *Fra:* Blumentrath, Stefan [mailto:Stefan.Blumentrath at nina.no]
> *Sendt:* 26. juni 2014 13:17
> *Til:* Stott, James; qgis-developer at lists.osgeo.org
> *Emne:* RE: SOSI support in QGIS
> Hi James,
> and sorry for not having answered your earlier email on that issue.
> On Windows I can reproduce your issue too. However, given that it worked
> on Mac, I suspect this is a packaging problem…
> In other words my fault. I shall try to fix it with an update of the
> gdal-sosi package asap.
> Yet, the Norwegian mapping authority mentioned that a 64bit build of the
> OpenFYBA library would be very much experimental… So no success guaranteed.
> If we do not get it workin,g we would probably have to remove the
> gdal-sosi package (until it works properly).
> Cheers
> Stefan
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140626/84b8e4c5/attachment-0001.html>
