[Qgis-developer] SOSI support in QGIS
Stott, James fmrojst at fylkesmannen.no
Thu Jun 26 06:04:02 PDT 2014
Hei Stefan,
Thanks for looking at this again.
Do you know why the SOSI option doesn't appear in 32 bit version?
With the release of 2.4 a day or so away, I wonder if its best to just remove the SOSI option from the file dialog box for the 2.4 release? That way people won't be under the impression that QGIS can open SOSI when it can't?
Don't know if anyone else agrees?
James
Fra: Blumentrath, Stefan [mailto:Stefan.Blumentrath at nina.no]
Sendt: 26. juni 2014 13:17
Til: Stott, James; qgis-developer at lists.osgeo.org
Emne: RE: SOSI support in QGIS
Hi James,
and sorry for not having answered your earlier email on that issue.
On Windows I can reproduce your issue too. However, given that it worked on Mac, I suspect this is a packaging problem...
In other words my fault. I shall try to fix it with an update of the gdal-sosi package asap.
Yet, the Norwegian mapping authority mentioned that a 64bit build of the OpenFYBA library would be very much experimental... So no success guaranteed.
If we do not get it workin,g we would probably have to remove the gdal-sosi package (until it works properly).
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140626/89ab366e/attachment.html>
