[Qgis-developer] 2.2 project keeps crashing after load
Andreas Neumann
a.neumann at carto.net
Fri Jun 27 01:56:51 PDT 2014
I will continue to try to simplify the project.
@Andrea: this is a different issue. My crash happens directly after
project load. Not when removing a layer.
Andreas
Am 27.06.2014 08:55, schrieb Martin Dobias:
> Hi Andreas
> On Fri, Jun 27, 2014 at 3:43 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> The crashes do not appear always. Maybe 1 out of 3 or 4. They appear
>> more often after a fresh start of QGIS.
>> I am afraid I cannot produce an easy to reproduce test-case.
> I understand - I didn't mean to prepare a project that would always
> replicate the problem. My idea was that if you could try to continue
> simplifying the project to get at least more hints what functionality
> must be used in order to still see the crashes (on your computer) - so
> we could at least rule out some options that may be causing it.
> Regards
> Martin
