[Qgis-developer] Renaming Save Style -> Save Properties (Vector layer dialog)
Nathan Woodrow
madmanwoo at gmail.com
Sat Mar 1 03:52:02 PST 2014
Hey Zoltan,
That pretty much is a thread hijack. Please start a new thread, and maybe
open a ticket for the feature request, which is a good one by the way.
- Nathan
On Sat, Mar 1, 2014 at 9:16 PM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
> On 2014/03/01 12:38, Nathan Woodrow wrote:
> Hey all,
> I would like to get some opinions on Save, Load, Restore Default Style..
> buttons. Personally I find these labeled wrong for what action they take.
> Originally these buttons would only save the information from the Style
> tab out to a .qml file however now that has evolved to saving other
> information that is not related to style, things like;:the edit forms;
> included WMS, excluded WMS, etc. To me these are more properties of the
> layer and less about the style so the name is misleading. Sharing these
> also becomes hard because if I only want the style part it can also
> override the label and form settings I have. Hand editing the XML is the
> only real option to remove the other settings, which is a pain
> Proposing: Rename from Save, Load Style to Save Properties, Load
> Properties.
> Motivation: I would like to add the ability to save just the style
> information out to a new file type (maybe something like .qstyle) that
> would just contain the renderer-v2 XML block. This would allow sharing of
> just the renderer style and would also give me the ability to expand the
> Style Manager to allow saving of prebuilt styles e.g I would like to
> premake a planning scheme style that all ready contains the right values to
> symbols that I could share and load. By Mixing non style information in
> the .qml files means this is not as simple as it could be.
> We could also expand the above logic to only save the label section out
> to create a label "style" manager.
> Thoughts?
> - Nathan
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Hi All,
> Please treat this as "thread enhancing" and not "thread hijacking" :-)
> If there are going to be modifications done to styling, please consider
> adding a feature whereby the various styles chosen or experimented with,
> are auto-saved for that mapsheet (perhaps in your project files).
> I find when editing, edge-matching or QAing various mapsheets, I want to
> easily switch between styles - I might choose "single symbol" for the map I
> am editing, but "rule-based" for the adjoining maps. Rule based choices
> would change depending on scenarios, so it does not make sense to save a
> rule-based set (I could end up with too many).
> So, what I am seeking is the ability to switch between the 5 style
> categories, and not lose the ones I may have set up a few minutes ago. If I
> close QGIS, and come back to the project later, I would like to see the
> last styles I had set up for a mapsheet, still be available when I click
> through the style options.
> Hope I'm making myself clear.
> Thanks & regards,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Service
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140301/bce6b8dc/attachment-0001.html>
