[Qgis-developer] Renaming Save Style -> Save Properties (Vector layer dialog)
Nathan Woodrow
madmanwoo at gmail.com
Sun Mar 2 04:11:30 PST 2014
> The only thing I am missing in this mockup is the ability to
> check/uncheck all checkboxes. It is kind of boring having to uncheck a
> lot of checkboxes if just want the styling or labeling.
Just an implementation detail. That is something I would add.
- Nathan
On Sun, Mar 2, 2014 at 10:06 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Nathan,
> Yes - I like the idea of a separate tab for import/export of layer
> properties.
> I guess the "Save style" would then be renamed to "Save Property"?
> Cool - looking forward to these improvements!
> Andreas
> Am 02.03.2014 11:58, schrieb Nathan Woodrow:
> > Andreas,
> > Something like this is what I was thinking. (With a better UI of course)
> > http://i.imgur.com/2XbNqlp.png
> > - Nathan
> > On Sun, Mar 2, 2014 at 9:45 PM, Nathan Woodrow <madmanwoo at gmail.com>
> wrote:
> >> Hey Andreas,
> >> I'm not 100% yet. I'm not sure what it is but I really hate the Load
> >> Style../Save Style buttons at the bottom of the dialog. I was thinking
> a
> >> new page in the properties dialog would be better with the title
> >> Import/Export. For me this would mean not having a open another dialog,
> >> which I really don't like the idea of, and we have more room to play
> with.
> >> One of my goals is to be able to export just the style part in order to
> >> expand the Style Manager to handle prebuilt styles. I was planning on
> >> adding some Save and Load buttons on the style tab that would just load
> the
> >> style information from the .qml file.
> >> - Nathan
> >> On Sun, Mar 2, 2014 at 9:39 PM, Andreas Neumann <a.neumann at carto.net
> >wrote:
> >>> Hi,
> >>> How do you envisage to implement this?
> >>> Personally I would think it would be useful to have an export dialogue
> >>> where the user can choose (with checkboxes or a list widget) which
> >>> properties he wants to export:
> >>> * General properties (like the filtering, encoding, layer alias, scale
> >>> dependent visibility, CRS )
> >>> * Style properties
> >>> * Labeling properties
> >>> * Field properties (incl. display field properties)
> >>> * Actions
> >>> * Joins and Relations (see the new relations manager that Matthias
> >>> recently introduced)
> >>> * Diagrams
> >>> * Metadata
> >>> As a shortcut one should be able to export all at once without having
> to
> >>> press all checkboxes.
> >>> When importing, the importer of the layer properties should list what
> is
> >>> available in the .qml file and offer just the available bits of the
> >>> layer properties. Again - a short cut to import all layer properties
> >>> would be useful.
> >>> Thanks,
> >>> Andreas
> >>> Am 01.03.2014 15:42, schrieb Anita Graser:
> >>>> Hi Michael,
> >>>> Am 01.03.2014, 15:55 Uhr, schrieb kimaidou <kimaidou at gmail.com>:
> >>>>> I also think it could be great to have a button
> >>>>> "save style". But the latest should not lie in the bottom of the
> layer
> >>>>> dialog, but instead in the Style tab only, to avoid confusion.
> >>>> +1
> >>>>> By the way, having a "save style" button could also lead to the
> >>>>> ability of
> >>>>> saving/restoring more than one style for each layer (via a combo box
> >>> for
> >>>>> the restore button), which could be great too.
> >>>> This could work quite well. Do you think the "Save style" button could
> >>>> be a simple button with the save icon or do we need a labeled button?
> >>>> Best wishes,
> >>>> Anita
> >>>>> Regards,
> >>>>> Michael
> >>>>> 2014-03-01 15:01 GMT+01:00 Régis Haubourg <
> >>>>> regis.haubourg at eau-adour-garonne.fr>:
> >>>>>> Hi Nathan I agree with your proposal of renaming style by
> properties.
> >>>>>> Users don't understand they also inherit labels, metadata and so on
> >>> when
> >>>>>> loading a style.
> >>>>>> By the way, I think some improvements can be made for reloading
> style
> >>>>>> use
> >>>>>> case. Problem occurs (maybe occured, didn't check recently) when
> user
> >>>>>> want
> >>>>>> to transfer graduated or single value style classes from one column
> to
> >>>>>> another. Copying style from another table often leads to that
> >>> situation,
> >>>>>> where field or expression is not in target table. I know this can
> be
> >>>>>> tricky since graduated classes are in autosync with numeric data.
> >>>>>> Another issue occurs when geometry type is not the same. Maybe we
> >>> could
> >>>>>> save
> >>>>>> at least color when reapplying style (from point to polygon for
> >>>>>> instance).
> >>>>>> This was my small thread highjack ;-)
> >>>>>> Cheers,
> >>>>>> Régis
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140302/210d5038/attachment-0001.html>
