[Qgis-developer] Renaming Save Style -> Save Properties (Vector layer dialog)
Mathieu Pellerin
nirvn.asia at gmail.com
Sun Mar 2 04:22:00 PST 2014
I like where it's going. Re check boxes, I'd love to see "intelligent"
switch buttons beyond "check all" "uncheck all". A "check styling only"
(symbology + label) button, a "check non - style only" button would be
really useful. Like some media players do to check audio only vs video &
audio.
On 2 Mar 2014 19:11, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
> The only thing I am missing in this mockup is the ability to
>> check/uncheck all checkboxes. It is kind of boring having to uncheck a
>> lot of checkboxes if just want the styling or labeling.
> Just an implementation detail. That is something I would add.
> - Nathan
> On Sun, Mar 2, 2014 at 10:06 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi Nathan,
>> Yes - I like the idea of a separate tab for import/export of layer
>> properties.
>> I guess the "Save style" would then be renamed to "Save Property"?
>> Cool - looking forward to these improvements!
>> Andreas
>> Am 02.03.2014 11:58, schrieb Nathan Woodrow:
>> > Andreas,
>> > Something like this is what I was thinking. (With a better UI of course)
>> > http://i.imgur.com/2XbNqlp.png
>> > - Nathan
>> > On Sun, Mar 2, 2014 at 9:45 PM, Nathan Woodrow <madmanwoo at gmail.com>
>> wrote:
>> >> Hey Andreas,
>> >> I'm not 100% yet. I'm not sure what it is but I really hate the Load
>> >> Style../Save Style buttons at the bottom of the dialog. I was
>> thinking a
>> >> new page in the properties dialog would be better with the title
>> >> Import/Export. For me this would mean not having a open another
>> dialog,
>> >> which I really don't like the idea of, and we have more room to play
>> with.
>> >> One of my goals is to be able to export just the style part in order to
>> >> expand the Style Manager to handle prebuilt styles. I was planning on
>> >> adding some Save and Load buttons on the style tab that would just
>> load the
>> >> style information from the .qml file.
>> >> - Nathan
>> >> On Sun, Mar 2, 2014 at 9:39 PM, Andreas Neumann <a.neumann at carto.net
>> >wrote:
>> >>> Hi,
>> >>> How do you envisage to implement this?
>> >>> Personally I would think it would be useful to have an export dialogue
>> >>> where the user can choose (with checkboxes or a list widget) which
>> >>> properties he wants to export:
>> >>> * General properties (like the filtering, encoding, layer alias, scale
>> >>> dependent visibility, CRS )
>> >>> * Style properties
>> >>> * Labeling properties
>> >>> * Field properties (incl. display field properties)
>> >>> * Actions
>> >>> * Joins and Relations (see the new relations manager that Matthias
>> >>> recently introduced)
>> >>> * Diagrams
>> >>> * Metadata
>> >>> As a shortcut one should be able to export all at once without having
>> to
>> >>> press all checkboxes.
>> >>> When importing, the importer of the layer properties should list what
>> is
>> >>> available in the .qml file and offer just the available bits of the
>> >>> layer properties. Again - a short cut to import all layer properties
>> >>> would be useful.
>> >>> Thanks,
>> >>> Andreas
>> >>> Am 01.03.2014 15:42, schrieb Anita Graser:
>> >>>> Hi Michael,
>> >>>> Am 01.03.2014, 15:55 Uhr, schrieb kimaidou <kimaidou at gmail.com>:
>> >>>>> I also think it could be great to have a button
>> >>>>> "save style". But the latest should not lie in the bottom of the
>> layer
>> >>>>> dialog, but instead in the Style tab only, to avoid confusion.
>> >>>> +1
>> >>>>> By the way, having a "save style" button could also lead to the
>> >>>>> ability of
>> >>>>> saving/restoring more than one style for each layer (via a combo box
>> >>> for
>> >>>>> the restore button), which could be great too.
>> >>>> This could work quite well. Do you think the "Save style" button
>> could
>> >>>> be a simple button with the save icon or do we need a labeled button?
>> >>>> Best wishes,
>> >>>> Anita
>> >>>>> Regards,
>> >>>>> Michael
>> >>>>> 2014-03-01 15:01 GMT+01:00 Régis Haubourg <
>> >>>>> regis.haubourg at eau-adour-garonne.fr>:
>> >>>>>> Hi Nathan I agree with your proposal of renaming style by
>> properties.
>> >>>>>> Users don't understand they also inherit labels, metadata and so on
>> >>> when
>> >>>>>> loading a style.
>> >>>>>> By the way, I think some improvements can be made for reloading
>> style
>> >>>>>> use
>> >>>>>> case. Problem occurs (maybe occured, didn't check recently) when
>> user
>> >>>>>> want
>> >>>>>> to transfer graduated or single value style classes from one
>> column to
>> >>>>>> another. Copying style from another table often leads to that
>> >>> situation,
>> >>>>>> where field or expression is not in target table. I know this
>> can be
>> >>>>>> tricky since graduated classes are in autosync with numeric data.
>> >>>>>> Another issue occurs when geometry type is not the same. Maybe we
>> >>> could
>> >>>>>> save
>> >>>>>> at least color when reapplying style (from point to polygon for
>> >>>>>> instance).
>> >>>>>> This was my small thread highjack ;-)
>> >>>>>> Cheers,
>> >>>>>> Régis
>> >>> _______________________________________________
>> >>> Qgis-developer mailing list
>> >>> Qgis-developer at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140302/87400186/attachment.html>
