[Qgis-developer] [QGIS-UX] Fwd: Re: Renaming Save Style -> Save Properties (Vector layer dialog)
Tim Sutton lists at linfiniti.com
Sun Mar 2 09:13:48 PST 2014
Hey Zoltan
On Sun, Mar 2, 2014 at 4:59 PM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
8<---------------------snip---------------------------------
Please consider this methodolgy:
> Currently, when QGIS loads a map layer, certain default things happen:
> Styles get assigned, etc etc.
> As a maplayer is loaded (or perhaps only when the user changes something
> (like style)), QGIS should dump a [maplayername].qgis file, text format,
> perhaps keyword-value layout, into the directory that the map is stored.
> This file will then contain all the internal QGIS defaults, and of course
> updates to the current (style ) status, as the user changes them.
> The benefits of using this implementation scheme could be vast:
>    - For deployment purposes, users could create/edit this file outside
>    of QGIS
>    - QGIS Dev could implement a methodology whereby user scripts could
>    read and write to this maplayer specific file - for example: map production
>    information whilst capture staff are creating features.
>    - This file could even be designed to live at the project level, and
>    at the user level - this way departmental level defaults could be set
>    (deployed), and for those users who need it, these could be over-ridden by
>    having that filename als local to the user, but with user specific values.
>     - Should any of these filenames only have some of the default
>    keyword-values, QGIS could look for the other defaults at higher filename
>    level (ie project level if user-level does not exist), or as currently, at
>    the internally stored default actions.
> And the downsides could be (if I understand your proposal correctly):
* Working on a shared file store you are going to wreak all kinds of havoc
with user experience as different users overwrite the same file concurrently
* Working with a read only directory it obviously wont work
* Working with remote datasources (PostGIS etc.) it won't work
 The above implementation strategy would not need a special "export" menu
> as the information would then always be stored in a user useable file.
> If this file becomes corrupt or nonsensical, QGIS actions could revert to
> the default internal actions.
> As time goes by, I reckon QGIS developers would find many more uses for
> this map-layer specific file mechanism, should it be available.
> Hope I'm making sense.
Not completely for me :-)
Regards
Tim
>  Kind regards,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Service
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323     www.geograph.co.za
>  _______________________________________________
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140302/0853e9c5/attachment-0001.html>
