[Qgis-developer] What about a qgis project add function ?
kimaidou kimaidou at gmail.com
Sun Mar 2 09:40:06 PST 2014
Brent,
Perhaps I have misunderstood your question, but I think you can achieve
this simply by "save style as default" . Every time you will use the layer
in any QGIS project, the default "style" (which mean the default properties
of the layer) would be applied.
Michael
2014-03-02 18:27 GMT+01:00 Brent Wood <pcreso at pcreso.com>:
> I suggest a slightly different approach (which may not be all that
> different once the details are  worked out?)
> A project stores lots of info about more items than just a layer... but I
> often want to add a layer with the same style, actions, label, etc settings
> to several projects, or just to the current canvas without changing what is
> already in the canvas.
> Does it seem useful to others to be able to store such info in a "layer
> setup" file rather than a QGIS project file, so layers can be opened with
> all such info attached & optionally read on opening?
> Regards,
>   Brent Wood
>  *From:* Paolo Cavallini <cavallini at faunalia.it>
> *To:* qgis-developer at lists.osgeo.org
> *Sent:* Sunday, March 2, 2014 9:27 PM
> *Subject:* Re: [Qgis-developer] What about a qgis project add function ?
> Il 01/03/2014 22:07, Régis Haubourg ha scritto:
> > I would love to call it "Add or embed from other project", and just add a
> > checkbox choose embed or hard copy of the layers and groups. Existing
> dialog
> > is already correct.
> > I just ported Import Project plugin to 2.0 to satisfy that need. Just be
> > aware that you need to give a new id to imported layers, to be able to
> > import some layers n times. Code is quite simple, I would love to see
> that
> > in core!
> +1
> Merci Régis.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140302/838a6b14/attachment.html>
