[Qgis-developer] Fwd: A pipinstall plugin is possible? First: What's the difference between the the Osgeo4w Shell?
Luca Mandolesi
mandoluca at gmail.com
Wed Mar 5 02:32:14 PST 2014
Hi to all,
I'm trying to realize a little plugin to install python modules on windows
via pip.
In first, I would like make a simple thing:
Run get-pip.py inside the plugin but I encounter two different problem:
What is the shell to call? (Please, don't mind If I point at dufour, is my
qgis crushtest dummy )
subprocess.call('C:\\PROGRA~2\\QGISDU~1\\Osgeo4W.bat python get-pip.py')
or
subprocess.call('"C:\Program Files (x86)\QGIS Dufour\OSGeo4W.bat python
get-pip.py')
Apparently they are the same, but if I install something through python
inside one, I cannot import the module inside the other.
So, what's the right way to call inside a python plugin the shell?
I found also some problems in using subprocess on windows, and I'm
developping using QProcess class.
Second question:
If I run
get-pip.py')
I receive: Nothing distributions at all found fo install...
So the solution are easy: distribute qgis with pip and easy_install inside,
or install pip and easy_intall from shell as I did, then we can use the
plugin as you check out in my screenshots:
[0]
So, if you have suggestions plese let me know.
Best regards
Luca
[0]
https://lh5.googleusercontent.com/-Z6xJHji33E8/UxURKBr1NpI/AAAAAAAADrg/2XWnxf7q6fA/w1075-h604-no/testpipinstaller.PNG
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140305/6b5e91a7/attachment.html>
