[Qgis-developer] Fwd: A pipinstall plugin is possible? First: What's the difference between the the Osgeo4w Shell?
Gino Pirelli luipir at gmail.com
Thu Mar 6 04:44:25 PST 2014
or we can manage a
- light way (light in the plugin point of view) with simple requirement.txt
(or whatever)
or a
- robust and idependent way managing virtualenv
or a
- kaos way mixing :)
Luigi Pirelli
On 6 March 2014 13:18, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> The only gotcha to this is that different plugins might require different
> versions of dependencies. We also toyed around in the past with the idea of
> each plugin having its own virtualenv for deps and then linking in the QGIS
> provided site_packages dir into that virtualenv too.
> Regards
> Tim
> On Thu, Mar 6, 2014 at 1:56 PM, Tom Kralidis <tomkralidis at gmail.com>wrote:
>> On Thu, 6 Mar 2014, G. Allegri wrote:
>>  Date: Thu, 6 Mar 2014 02:31:41 -0800
>>> From: G. Allegri <giohappy at gmail.com>
>>> To: Nathan Woodrow <madmanwoo at gmail.com>
>>> Cc: qgis-developer List <qgis-developer at lists.osgeo.org>
>>> Subject: Re: [Qgis-developer] Fwd: A pipinstall plugin is possible?
>>> First:
>>>> Windows doesn't ship with any version of Python. Yay Windows!  So we
>>>> bundle our own.  I personally don't mind this so much because it's
>>>> easier
>>>> to control the setup if we bundle it.
>>>> The main thing here is just including pip and easy_install in all the
>>>> windows installs, standalone and osgeo4w.  Jurgen has told me that
>>>> easy_install is included in the 64 bit versions but not 32 bit
>>>> versions. Is
>>>> that correct Jurgen?
>>>> If pip is included we can easily have plugins tell us what they need and
>>>> we can install them.
>>> +1, this is exactly what I was imaging.
>>> A requirements.txt for pip would be all that a dev should write.
>> +1, this would be great (we currently manage and bundle deps in MetaSearch
>> as a workaround).
>> - we would have to make sure the requirements file is standardized
>>   (others may have different / additional ones, like requirements-dev.txt,
>>   pip-requirements.txt, etc.).
>> - for MetaSearch, the requirements.txt file never makes it to the QGIS
>>   runtime, so plugin providers would need to make sure it does
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140306/28b8a8c5/attachment.html>
