[Qgis-developer] uploading plugin files to hub.qgis.org
    Alex Mandel
    tech_dev at wildintellect.com
    Thu Mar  6 15:32:02 PST 2014
Are you trying to upload a release of your plugin or looking to host the
source code and bug tracker of the plugin?
Release of plugins is handled separately via plugins.qgis.org
What you've pointed out is a bug that the admins need to figure out why
something changed. I have a working repo key with hub as do many others,
so the interface was there at some point. I'm copying the person who
originally setup the site to see if they know what's going on.
Thanks,
Alex
On 03/05/2014 12:18 AM, Giuseppe De Marco wrote:
> Allright then what is the working procedure to upload a plugin
> other than having an external git repo.
> Besides given that you have to upload to an external
> server how can you modify your repository configuration
> inside hub.qgis.org to point to your external repo?
> thank you!
> 2014-03-04 21:21 GMT+01:00 Alex Mandel <tech_dev at wildintellect.com>:
>> On 03/04/2014 04:33 AM, Giuseppe De Marco wrote:
>>> Hello,
>>> I have registered at hub.qgis.org and I have created 2 subprojects activating
>>> the option repository in settings.
>>> I have some problems authenticating with git:
>>> 1) I cannot upload my public key because it says that
>>> http://hub.qgis.org/my/public_keys page not found
>>> 2) obviously when I try to git push origin it asks for a password..
>>> this is what I get
>>> joe at U36SD:~/.qgis2/python/plugins/SelectTools$ git remote -v
>>> origin    gitosis at qgis.org:selecttools.git (fetch)
>>> origin    gitosis at qgis.org:selecttools.git (push)
>>> can somebody help me out?
>>> Thank you
>> You are right, something is amiss. I can't tell which Redmine plugin is
>> supposed to handle that. I expected to see something like the Gitosis
>> plugin but there's only a post-commit hook and a qgis customization
>> plugin. Neither of which integrate with git keys on the back end.
>> Did someone change the configuration of Redmine?
>> Thanks,
>> Alex
