[Qgis-developer] Common QGIS Plugin configuration accross multiple Linux users
Tim Sutton lists at linfiniti.com
Sun Mar 9 10:55:47 PDT 2014
Hi
On Sun, Mar 9, 2014 at 7:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi Zoltan
> On Sun, Mar 9, 2014 at 7:40 PM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
>> Hi,
>> I have posted this a couple of hours ago on QGIS-user, but this might be
>> more of a dev question:
>> I've got a number of users created on an Ubuntu 13.10 PC.
>> Is there a way that I can add the same plugins and proliferate the same
>> QGIS configuration to all users?
>> Perhaps by updating a master-User (icon arrangement, plugins etc) and
>> then copying that config file to the other users?
>> If yes, what files need to be copied accross?
> The two directories you care about in this case are
> ~/.qgis2
Sorry actually more specifically you probably only want to sync the plugins
dir at ~/.qgis2/python/plugins
> and
> ~/.config/QGIS
> You could e.g. rsync the user plugin dirs from a central one, or put them
> in an nfs mount (read only might have issues as plugins try to write .pyc
> files or even write data to the plugin dir).
> The ~/.config/QGIS/QGIS2.conf is a standard ini style config file so you
> should be able to pick through it and awk/sed/bash your way to nirvana :-)
> Regards
> Tim
>> Regards & thanks,
>> Zoltan
>> Zoltan Szecsei PrGISc [PGP0031]
>> Geograph (Pty) Ltd.
>> GIS and Photogrammetric Service
>> P.O. Box 7, Muizenberg 7950, South Africa.
>> Mobile: +27-83-6004028
>> Fax:    +27-86-6115323     www.geograph.co.za
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140309/24125609/attachment.html>
