[Qgis-developer] Common QGIS Plugin configuration accross multiple Linux users
Zoltan Szecsei
zoltans at geograph.co.za
Sun Mar 9 11:08:43 PDT 2014
Great - thanks Tim,
Cheers for now,
Zoltan
On 2014/03/09 19:54, Tim Sutton wrote:
> Hi Zoltan
> On Sun, Mar 9, 2014 at 7:40 PM, Zoltan Szecsei <zoltans at geograph.co.za
> <mailto:zoltans at geograph.co.za>> wrote:
> Hi,
> I have posted this a couple of hours ago on QGIS-user, but this
> might be more of a dev question:
> I've got a number of users created on an Ubuntu 13.10 PC.
> Is there a way that I can add the same plugins and proliferate the
> same QGIS configuration to all users?
> Perhaps by updating a master-User (icon arrangement, plugins etc)
> and then copying that config file to the other users?
> If yes, what files need to be copied accross?
> The two directories you care about in this case are
> ~/.qgis2
> and
> ~/.config/QGIS
> You could e.g. rsync the user plugin dirs from a central one, or put
> them in an nfs mount (read only might have issues as plugins try to
> write .pyc files or even write data to the plugin dir).
> The ~/.config/QGIS/QGIS2.conf is a standard ini style config file so
> you should be able to pick through it and awk/sed/bash your way to
> nirvana :-)
> Regards
> Tim
> Regards & thanks,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Service
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028 <tel:%2B27-83-6004028>
> Fax: +27-86-6115323 <tel:%2B27-86-6115323> www.geograph.co.za
> <http://www.geograph.co.za>
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net <http://freenode.net>
Geograph (Pty) Ltd.
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140309/0588341c/attachment.html>
