[Qgis-developer] Postgis Spatial Views - problems with primary keys
Alexandre Neto senhor.neto at gmail.com
Mon Mar 10 05:03:54 PDT 2014
Hello,
In Valmiera, I started to have problems with QGIS using postgis spatial
views.
Adding a spatial view using the browser throws the following error:
"The layer dbname='postgis' host=192.168.100.7 port=5432 user='postgres'
> password='postgres' sslmode=disable key='cadeado' srid=3763 type=POINT
> table="PGHP"."infra_portoes" (geom) sql= is not a valid layer and can not
> be added to the map"
Adding the spatial view using the "add postgis layer", the layer can be
added (sometimes) but with odd behaviors.
I then noticed that using the last method, QGIS fails to identify a good
candidate for a primary key. Selecting it in the primary key, solves the
problem.
Using DB Manager (add layer to canvas), QGIS sucessfully identify the
possible primary key and everything goes well.
I think this was not happening in 2.0.1. Can anyone confirm this?
Best Regards,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140310/81318aa6/attachment.html>
