[Qgis-developer] [gdal-dev] Fix for QGIS 2.2+ Projection issue with OSGB36 NTv2
Etienne Tourigny etourigny.dev at gmail.com
Tue Mar 11 10:23:46 PDT 2014
You email should be sent to the qgis-developer list (this is the gdal-dev
list), which I am forwarding this to.
On Tue, Mar 11, 2014 at 7:44 AM, Nicholas Duggan
<dragons8mycat at live.co.uk>wrote:
> Hi all,
> I'm trying to get my fix for the OSGB36 to WGS84 using Ordnance Surveys
> OSTN02 (NTv2) transformation into the QGIS master. Nathan Woodrow
> recommended I bring it up with you guys who might be able to implement it.
> Essentially I've updated the QGIS srs.db and put the OSTN02_NTv2.gsb in
> the Share/Proj folder, full description and files are here:
> http://dragons8mycat.wordpress.com/2014/03/03/gis-tips-getting-ostn02-to-work-with-qgis-2-2/
> Is this something which can be implemented by yourselves or can you point
> me in the right direction for getting it put in the master/future releases?
> Thanks,
> Nick D (@dragons8mycat)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140311/9aec4594/attachment.html>
