[Qgis-developer] [gdal-dev] Fix for QGIS 2.2+ Projection issue with OSGB36 NTv2
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu Mar 13 00:27:55 PDT 2014
Hi
I'm adding the entries for OSGB36 NTv2 to srs.db.
For the .gsb file, you could probably contact the proj4 project if they
want it to distribute it togethere with the library (if the license
allows that).
Regards,
Marco
On 11.03.2014 18:23, Etienne Tourigny wrote:
> You email should be sent to the qgis-developer list (this is the
> gdal-dev list), which I am forwarding this to.
> On Tue, Mar 11, 2014 at 7:44 AM, Nicholas Duggan
> <dragons8mycat at live.co.uk <mailto:dragons8mycat at live.co.uk>> wrote:
> Hi all,
> I'm trying to get my fix for the OSGB36 to WGS84 using Ordnance
> Surveys OSTN02 (NTv2) transformation into the QGIS master. Nathan
> Woodrow recommended I bring it up with you guys who might be able
> to implement it.
> Essentially I've updated the QGIS srs.db and put the
> OSTN02_NTv2.gsb in the Share/Proj folder, full description and
> files are here:
> http://dragons8mycat.wordpress.com/2014/03/03/gis-tips-getting-ostn02-to-work-with-qgis-2-2/
> Is this something which can be implemented by yourselves or can
> you point me in the right direction for getting it put in the
> master/future releases?
> Thanks,
> Nick D (@dragons8mycat)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140313/41d137a0/attachment.html>
