[Qgis-developer] Data defined symbol dimension: bug?
Giovanni Manghi
giovanni.manghi at faunalia.pt
Tue Mar 11 11:49:51 PDT 2014
> Hi all.
> I noticed a strange behaviour in data defined symbol size. With this expression:
> ( year( "data_inizio" )-1985) /10
> I get the attached image1.jpg (labels are made with the same expression).
> With this one:
> ( year( "data_inizio" )) /100
> I get image2.jpg, also attached. Same scale. So size is calculated correctly, but
> displayed wrongly.
> Seems like a bug, right?
if I define an expression like
("column_int" -1985)/4+5
the preview is ok, but...
after re-opening the expression for the data defined size it shows as
"column_int" - 1985/4+5
the parentheses are gone and of course the result is much different
from the expected one...
cheers!
