[Qgis-developer] [gdal-dev] Fix for QGIS 2.2+ Projection issue with OSGB36 NTv2
Etienne Tourigny
etourigny.dev at gmail.com
Fri Mar 14 07:57:20 PDT 2014
On Fri, Mar 14, 2014 at 10:44 AM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi
> The info for OSGB36 NTv2 is in srs.db now.
> >Makes me think - could QGIS ship with the freely available gsb grids, in
> an optional package (say qgis-datum-grids)? It would be rather convenient,
> especially as QGIS now >supports them (but does not ship with any grids
> yet, unless mistaken).
> I'm receiving frequent suggestions of bundling .gsb files with QGIS. The
> problems I see with this are:
> - It adds the extra MB for QGIS too.
it should be an extra package, not part of main QGIS packages (for osgeo4w
and linux)
> - They come with various licences.
that would require a bit of time to make sure all added packages are ok to
distribute, but it's a one-time process.
> - .gsb files are usefull for all tools working with proj. So a logical
> choice would be to have an optional package for proj4.
Yes, but that would be up to others not QGIS, so adding them to the QGIS
packages would have more chances of actually happening.
It would be nice to have a point of view from those responsible for
packaging QGIS.
cheers,
Etienne
> Regards,
> Marco
> On 13.03.2014 18:20, Etienne Tourigny wrote:
> On Thu, Mar 13, 2014 at 4:27 AM, Marco Hugentobler <
>> Hi
>> I'm adding the entries for OSGB36 NTv2 to srs.db.
>> For the .gsb file, you could probably contact the proj4 project if they
>> want it to distribute it togethere with the library (if the license allows
>> that).
> I guess that's unlikely they would add it to the binary packages, as it
> would add a few MB to the base install. But they might add it to
> proj-datumgrid-1.5.zip (which contains many free datum files), as the
> licence for the grid is BSD.
> especially as QGIS now supports them (but does not ship with any grids yet,
> unless mistaken).
> cheers,
> Etienne
>> Regards,
>> Marco
>> On 11.03.2014 18:23, Etienne Tourigny wrote:
>> You email should be sent to the qgis-developer list (this is the
>> gdal-dev list), which I am forwarding this to.
>> On Tue, Mar 11, 2014 at 7:44 AM, Nicholas Duggan <
>> dragons8mycat at live.co.uk> wrote:
>>> Hi all,
>>> I'm trying to get my fix for the OSGB36 to WGS84 using Ordnance Surveys
>>> OSTN02 (NTv2) transformation into the QGIS master. Nathan Woodrow
>>> recommended I bring it up with you guys who might be able to implement it.
>>> Essentially I've updated the QGIS srs.db and put the OSTN02_NTv2.gsb in
>>> the Share/Proj folder, full description and files are here:
>>> http://dragons8mycat.wordpress.com/2014/03/03/gis-tips-getting-ostn02-to-work-with-qgis-2-2/
>>> Is this something which can be implemented by yourselves or can you
>>> point me in the right direction for getting it put in the master/future
>>> releases?
>>> Thanks,
>>> Nick D (@dragons8mycat)
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140314/de315723/attachment.html>
