[Qgis-developer] Problem with GDAL_translate. REST Services, QGIS
Alex Mandel
tech_dev at wildintellect.com
Thu Mar 13 10:28:14 PDT 2014
I wouldn't get on his case too hard he's following:
http://hub.qgis.org/wiki/quantum-gis/Arcgis_rest
There's probably some clues in:
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/The_ArcGIS_REST_API/02r300000054000000/
I think other workarounds could be to pull the layers in the OpenLayers
plugin.
Thanks,
Alex
On 03/13/2014 09:50 AM, Lauri Kajan wrote:
> Hi Randy,
> You are requesting json format from arcgisonline. That is a vector format
> and you are trying to use it as a raster image.
> Secondly you are trying to translate that into WMS with gdal_translate.
> Gdal supports WMS-reading only, not creation (
> http://gdal.org/formats_list.html).
> I recommend for you some introduction to GIS and raster and vector formats.
> http://www.qgis.org/en/docs/gentle_gis_introduction/index.html
> Regards,
> Lauri
> On Thu, Mar 13, 2014 at 4:51 PM, Randal Hale <
> rjhale at northrivergeographic.com> wrote:
>> So I figured I would start here and work my way out...or up. Sorry for the
>> cross posting. I'm hitting a little bit of everything on this one. Same
>> action - different results (sorta). This is all of my attempts at adding a
>> REST Service from ArcGISOnline to QGIS (using GDAL in some cases).
>> On Ubuntu 12.04 LTS gdal 1.10
>> This command: gdal_translate "http://server.arcgisonline.
>> com/ArcGIS/rest/services/USA_Topo_Maps/MapServer?f=json&pretty=true"
>> ESRITopographicLayer.xml -of WMS
>> Gives me a segmentation fault
>> On windows 7 OSGEO4w 32 bit installer gdal 1.10.1
>> Gives me:
>> ERROR 4: `/vsimem/http_1/file.dat' not recognised as a supported file
>> format.
>> ERROR 4: `/tmp/file.dat' not recognised as a supported file format.
>> GDALOpen failed - 4
>> In QGIS 2.2 On windows (OSGEo4W installer) python console:
>> qgis.utils.iface.addRasterLayer("http://server.
>> arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/
>> MapServer?f=json&pretty=true","raster")
>> Gives me an error saying /tmp/file.dat is not a recognized format.
>> On Ubuntu 12.04 QGIS 2.2 Python Console
>> Crashes QGIS.
>> Once again my apologies for cross posting. I *think* it's all related. I
>> think.
>> Randy
>> Randal Hale, GISP
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale
>> http://about.me/rjhale
