[Qgis-developer] Problem with GDAL_translate. REST Services, QGIS
Alex Mandel
tech_dev at wildintellect.com
Thu Mar 13 12:03:56 PDT 2014
Randy,
So it was working at some point? Is it possible the service has changed?
Thanks,
Alex
On 03/13/2014 11:21 AM, Randal Hale wrote:
> No worries at all!
> I just need to figure out why it stopped working.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale
> http://about.me/rjhale
> On 03/13/2014 01:55 PM, Lauri Kajan wrote:
>> Hi Randy,
>> I'm really sorry and little embarrassed for my previous post.
>> You sure noticed that I don't have much knowledge in arcgis rest
>> services and especially in using those with gdal.
>> In this case that json isn't a vector data. It is actually a
>> description of a raster service and therefore should be accetable for
>> gdal. This was totally my mistake.
>> -Lauri
>> On Thu, Mar 13, 2014 at 7:28 PM, Alex Mandel
>> <tech_dev at wildintellect.com <mailto:tech_dev at wildintellect.com>> wrote:
>> I wouldn't get on his case too hard he's following:
>> http://hub.qgis.org/wiki/quantum-gis/Arcgis_rest
>> There's probably some clues in:
>> http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/The_ArcGIS_REST_API/02r300000054000000/
>> I think other workarounds could be to pull the layers in the
>> OpenLayers
>> plugin.
>> Thanks,
>> Alex
>> On 03/13/2014 09:50 AM, Lauri Kajan wrote:
>> > Hi Randy,
>> > You are requesting json format from arcgisonline. That is a
>> vector format
>> > and you are trying to use it as a raster image.
>> > Secondly you are trying to translate that into WMS with
>> gdal_translate.
>> > Gdal supports WMS-reading only, not creation (
>> > http://gdal.org/formats_list.html).
>> > I recommend for you some introduction to GIS and raster and
>> vector formats.
>> > http://www.qgis.org/en/docs/gentle_gis_introduction/index.html
>> > Regards,
>> > Lauri
>> > On Thu, Mar 13, 2014 at 4:51 PM, Randal Hale <
>> <mailto:rjhale at northrivergeographic.com>> wrote:
>> >> So I figured I would start here and work my way out...or up.
>> Sorry for the
>> >> cross posting. I'm hitting a little bit of everything on this
>> one. Same
>> >> action - different results (sorta). This is all of my attempts
>> at adding a
>> >> REST Service from ArcGISOnline to QGIS (using GDAL in some cases).
>> >> On Ubuntu 12.04 LTS gdal 1.10
>> >> This command: gdal_translate "http://server.arcgisonline.
>> com/ArcGIS/rest/services/USA_Topo_Maps/MapServer?f=json&pretty=true"
>> >> ESRITopographicLayer.xml -of WMS
>> >> Gives me a segmentation fault
>> >> On windows 7 OSGEO4w 32 bit installer gdal 1.10.1
>> >> Gives me:
>> >> ERROR 4: `/vsimem/http_1/file.dat' not recognised as a
>> supported file
>> >> format.
>> >> ERROR 4: `/tmp/file.dat' not recognised as a supported file
>> format.
>> >> GDALOpen failed - 4
>> >> In QGIS 2.2 On windows (OSGEo4W installer) python console:
>> >> qgis.utils.iface.addRasterLayer("http://server.
>> >> arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/
>> <http://arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/>
>> >> MapServer?f=json&pretty=true","raster")
>> >> Gives me an error saying /tmp/file.dat is not a recognized format.
>> >> On Ubuntu 12.04 QGIS 2.2 Python Console
>> >> Crashes QGIS.
>> >> Once again my apologies for cross posting. I *think* it's all
>> related. I
>> >> think.
>> >> Randy
>> >> Randal Hale, GISP
>> >> 423.653.3611 <tel:423.653.3611> rjhale at northrivergeographic.com
>> >> twitter:rjhale
