[Qgis-developer] Print composer: map rotation
Andreas Neumann a.neumann at carto.net
Sat Mar 15 10:04:22 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Paolo,
This is not a bug. Every object in the composer can be rotated now. It
is a general feature of all objects in the print composer.
The other rotation is just the map content, which is different from
rotating the map frame.
Of course you could do stupid things with it - but then you can do
that with a lot of other features within QGIS.
Andreas
Am 14.03.2014 15:07, schrieb Paolo Cavallini:
> Hi all. I noticed that the map cen be rotated both inside a frame,
> or with the frame as a whole. In the first case an image (e.g.
> north arrow) can be rotated in sync, in the second not; IMHO this
> is a bug. Opinions? All the best.
> _______________________________________________ Qgis-developer
> mailing list Qgis-developer at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTJIgWAAoJELiCsGDopvBCAI0H/1AhGP3R8/qcjiIoQQ0P3J6u
N+zfjCx19BeivClMeHZL8WRNxQhDXmGQr2b4S29TpChWI/lZp+Z1D8W0Aa6ssWV8
rpdBR8bcbp+hvkNktQKGnvjFJdDd+zV/2giGRjMU/aniHrHhA3L7uXZUVlfuWZuF
JOuyfnr3g78Rqs1Zr5YqlJWLFUBmUimazjRUHlmX1vwDHrD/NsfGQCxdnbMSBopV
XmtqNwVVkojqqdfLPy1uTkWblUmNSqItTdHYr/W/x4IgG1VGpwRDXM/U8aBneld9
iXyb1WT6SXPsGACUarCy2ANqROm5UJbsLjHWwai7id0hLI/wVuwqCuL2qIWYzT4=
=YpEk
-----END PGP SIGNATURE-----
