[Qgis-developer] [Feature][RASTER] Generate band name with NetCDF EXTRA_DIM funded by Ifremer
rldhont
rldhont at gmail.com
Tue Mar 18 08:58:36 PDT 2014
Hi dev,
I have open an issue http://hub.qgis.org/issues/9810 and a pull request
https://github.com/qgis/QGIS/pull/1253
The NetCDF provided extra dimensional information. This information
provides metadata on each band. These metadat can be used to explain the
name of each band.
For example, the bands of a NetCDF file represents the temperature at a
given depth. For the user, it is easier to select a band with depth
information, rather than the number.
If the GDAL version is equal or greater than 1.10.0, the band name is
generated with the extra_dim information.
Regards,
René-Luc D'Hont
3Liz
