[Qgis-developer] Crash when activating Value Tool plugin
Paolo Cavallini
cavallini at faunalia.it
Wed Mar 19 09:04:00 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
I have Value tool installed; when I activate it from the plugin manager, I get a crash.
Master, just recompliled.
Anyone confirms?
All the best.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
warning: no loadable sections found in added symbol-file system-supplied DSO at
0x7ffffc34c000
0x00007f54a3814cf9 in __libc_waitpid (pid=24744, stat_loc=0x7ffffc2ff93c, options=0)
at ../sysdeps/unix/sysv/linux/waitpid.c:40
40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f54ab07d7c0 (LWP 24648))]
#0 0x00007f54a3814cf9 in __libc_waitpid (pid=24744, stat_loc=0x7ffffc2ff93c,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
resultvar = 0
oldtype = 0
#1 0x00000000004f7f17 in qgisCrash(int) ()
No symbol table info available.
#2 <signal handler called>
No locals.
#3 0x00007f54a5e1f15f in QPen::operator=(QPen const&) () from
/usr/lib/x86_64-linux-gnu/libQtGui.so.4
#4 0x00007f5461791998 in QwtSymbol::clone() const () from /usr/lib/libqwt-qt4.so.5
#5 0x00007f5461a66220 in ?? () from /usr/lib/python2.7/dist-packages/PyQt4/Qwt5/Qwt.so
#6 0x00007f546179b8fa in QwtPlotCurve::setSymbol(QwtSymbol const&) () from
#7 0x00007f5461aa5011 in ?? () from /usr/lib/python2.7/dist-packages/PyQt4/Qwt5/Qwt.so
#8 0x00007f547bec6854 in PyEval_EvalFrameEx () from
/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#9 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
#10 0x00007f547bec88fd in PyEval_EvalCodeEx () from
#11 0x00007f547bec8a90 in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#12 0x00007f547bea86b3 in PyObject_Call () from
#13 0x00007f547be3311d in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#14 0x00007f547bea86b3 in PyObject_Call () from
#15 0x00007f547beacf1f in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#16 0x00007f547beaaf2f in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
#17 0x00007f547bea86b3 in PyObject_Call () from
#18 0x00007f547bec3f96 in PyEval_EvalFrameEx () from
#19 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
#20 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
#21 0x00007f547bec88fd in PyEval_EvalCodeEx () from
#22 0x00007f547bec8be2 in PyEval_EvalCode () from
#23 0x00007f547bdf3ce9 in PyRun_StringFlags () from
#24 0x00007f547c2f1018 in QgsPythonUtilsImpl::evalString(QString const&, QString&) ()
from /usr/lib/libqgispython.so.2.3.0
#25 0x00007f547c2ee291 in QgsPythonUtilsImpl::startPlugin(QString) () from
#26 0x00000000006a080a in QgsPluginRegistry::loadPythonPlugin(QString) ()
#27 0x00000000007bd8b2 in QgsPluginManager::loadPlugin(QString) ()
#28 0x00000000007cafb3 in QgsPluginManager::pluginItemChanged(QStandardItem*) ()
#29 0x00000000007fc46c in ?? ()
#30 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject const*, int,
void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#31 0x00007f54a622be2f in QStandardItemModel::itemChanged(QStandardItem*) () from
#32 0x00007f54a622bee6 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#33 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject const*, int,
#34 0x00007f54a696a407 in QAbstractItemModel::dataChanged(QModelIndex const&,
QModelIndex const&) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#35 0x00007f54a622c3a0 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#36 0x00007f54a622ce5d in QStandardItem::setData(QVariant const&, int) () from
#37 0x00007f54a622f9f0 in QStandardItemModel::setData(QModelIndex const&, QVariant
const&, int) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#38 0x00007f54a621e514 in QSortFilterProxyModel::setData(QModelIndex const&, QVariant
#39 0x00007f54a623f219 in QStyledItemDelegate::editorEvent(QEvent*,
QAbstractItemModel*, QStyleOptionViewItem const&, QModelIndex const&) () from
#40 0x00007f54a61a0a92 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#41 0x00007f54a61a6e0b in QAbstractItemView::edit(QModelIndex const&,
QAbstractItemView::EditTrigger, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#42 0x00007f54a61a0d85 in QAbstractItemView::mouseReleaseEvent(QMouseEvent*) () from
#43 0x00007f54a61ca12e in QListView::mouseReleaseEvent(QMouseEvent*) () from
#44 0x00007f54a5cfcc9a in QWidget::event(QEvent*) () from
#45 0x00007f54a609adfe in QFrame::event(QEvent*) () from
#46 0x00007f54a61aa013 in QAbstractItemView::viewportEvent(QEvent*) () from
#47 0x00007f54a690c656 in
QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) () from
#48 0x00007f54a5cad6ac in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#49 0x00007f54a5cb3e7d in QApplication::notify(QObject*, QEvent*) () from
#50 0x00007f54a7b45feb in QgsApplication::notify(QObject*, QEvent*) () from
/usr/lib/libqgis_core.so.2.3.0
#51 0x00007f54a690c4ed in QCoreApplication::notifyInternal(QObject*, QEvent*) () from
#52 0x00007f54a5cb3633 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*,
QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from
#53 0x00007f54a5d252fb in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#54 0x00007f54a5d23d6c in QApplication::x11ProcessEvent(_XEvent*) () from
#55 0x00007f54a5d4b6c2 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#56 0x00007f54a208f526 in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#57 0x00007f54a208f878 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#58 0x00007f54a208f91c in g_main_context_iteration () from
#59 0x00007f54a6939725 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#60 0x00007f54a5d4b776 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#61 0x00007f54a690b0bf in
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
#62 0x00007f54a690b3b5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#63 0x00007f54a6150d4c in QDialog::exec() () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#64 0x00007f547986278f in ?? () from /usr/lib/python2.7/dist-packages/qgis/gui.so
#65 0x00007f547bec6854 in PyEval_EvalFrameEx () from
#66 0x00007f547bec88fd in PyEval_EvalCodeEx () from
#67 0x00007f547bec6558 in PyEval_EvalFrameEx () from
#68 0x00007f547bec88fd in PyEval_EvalCodeEx () from
#69 0x00007f547bec8be2 in PyEval_EvalCode () from
#70 0x00007f547bdf3ce9 in PyRun_StringFlags () from
#71 0x00007f547c2edaa9 in QgsPythonUtilsImpl::runStringUnsafe(QString const&, bool)
() from /usr/lib/libqgispython.so.2.3.0
#72 0x00007f547c2ef2a3 in QgsPythonUtilsImpl::runString(QString const&, QString,
bool) () from /usr/lib/libqgispython.so.2.3.0
#73 0x000000000053848f in QgsPythonRunnerImpl::runCommand(QString, QString) ()
#74 0x00007f54a7c656a2 in QgsPythonRunner::run(QString, QString) () from
#75 0x0000000000505a2a in QgisApp::showPluginManager() ()
#76 0x00000000007ee245 in ?? ()
#77 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject const*, int,
#78 0x00007f54a5ca7572 in QAction::triggered(bool) () from
#79 0x00007f54a5ca8f43 in QAction::activate(QAction::ActionEvent) () from
#80 0x00007f54a60d32f9 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#81 0x00007f54a60d7829 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#82 0x00007f54a5cfcc9a in QWidget::event(QEvent*) () from
#83 0x00007f54a60db62b in QMenu::event(QEvent*) () from
#84 0x00007f54a5cad6cc in QApplicationPrivate::notify_helper(QObject*, QEvent*) ()
#85 0x00007f54a5cb3e7d in QApplication::notify(QObject*, QEvent*) () from
#86 0x00007f54a7b45feb in QgsApplication::notify(QObject*, QEvent*) () from
#87 0x00007f54a690c4ed in QCoreApplication::notifyInternal(QObject*, QEvent*) () from
#88 0x00007f54a5cb3633 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*,
#89 0x00007f54a5d2562c in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#90 0x00007f54a5d23d6c in QApplication::x11ProcessEvent(_XEvent*) () from
#91 0x00007f54a5d4b6c2 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#92 0x00007f54a208f526 in g_main_context_dispatch () from
#93 0x00007f54a208f878 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#94 0x00007f54a208f91c in g_main_context_iteration () from
#95 0x00007f54a6939725 in
#96 0x00007f54a5d4b776 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#97 0x00007f54a690b0bf in
#98 0x00007f54a690b3b5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#99 0x00007f54a6910b89 in QCoreApplication::exec() () from
#100 0x00000000004f28f3 in main ()
gdb returned 0
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlMpv/AACgkQ/NedwLUzIr69GwCfUaosDL4X2l2ot2Y9NgSf/9+3
KL4AniDBPns8e4eJZvAANvBEx/5sP1e1
=jDLm
-----END PGP SIGNATURE-----
