[Qgis-developer] Crash when activating Value Tool plugin
Etienne Tourigny
etourigny.dev at gmail.com
Wed Mar 19 10:48:34 PDT 2014
what OS are you running? my bet is debian... might be related to this bug
- a conflict between qwt5 and qwt6. Please add info to this bug report...
http://hub.qgis.org/issues/7450
On Wed, Mar 19, 2014 at 1:04 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I have Value tool installed; when I activate it from the plugin manager, I
> get a crash.
> Master, just recompliled.
> Anyone confirms?
> All the best.
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> warning: no loadable sections found in added symbol-file system-supplied
> DSO at
> 0x7ffffc34c000
> 0x00007f54a3814cf9 in __libc_waitpid (pid=24744, stat_loc=0x7ffffc2ff93c,
> options=0)
> at ../sysdeps/unix/sysv/linux/waitpid.c:40
> 40 ../sysdeps/unix/sysv/linux/waitpid.c: File o directory non
> esistente.
> [Current thread is 1 (Thread 0x7f54ab07d7c0 (LWP 24648))]
> #0 0x00007f54a3814cf9 in __libc_waitpid (pid=24744,
> options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:40
> resultvar = 0
> oldtype = 0
> #1 0x00000000004f7f17 in qgisCrash(int) ()
> No symbol table info available.
> #2 <signal handler called>
> No locals.
> #3 0x00007f54a5e1f15f in QPen::operator=(QPen const&) () from
> /usr/lib/x86_64-linux-gnu/libQtGui.so.4
> #4 0x00007f5461791998 in QwtSymbol::clone() const () from
> /usr/lib/libqwt-qt4.so.5
> #5 0x00007f5461a66220 in ?? () from
> /usr/lib/python2.7/dist-packages/PyQt4/Qwt5/Qwt.so
> #6 0x00007f546179b8fa in QwtPlotCurve::setSymbol(QwtSymbol const&) () from
> #7 0x00007f5461aa5011 in ?? () from
> #8 0x00007f547bec6854 in PyEval_EvalFrameEx () from
> /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
> #9 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
> #10 0x00007f547bec88fd in PyEval_EvalCodeEx () from
> #11 0x00007f547bec8a90 in ?? () from
> #12 0x00007f547bea86b3 in PyObject_Call () from
> #13 0x00007f547be3311d in ?? () from
> #14 0x00007f547bea86b3 in PyObject_Call () from
> #15 0x00007f547beacf1f in ?? () from
> #16 0x00007f547beaaf2f in ?? () from
> #17 0x00007f547bea86b3 in PyObject_Call () from
> #18 0x00007f547bec3f96 in PyEval_EvalFrameEx () from
> #19 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
> #20 0x00007f547bec67d9 in PyEval_EvalFrameEx () from
> #21 0x00007f547bec88fd in PyEval_EvalCodeEx () from
> #22 0x00007f547bec8be2 in PyEval_EvalCode () from
> #23 0x00007f547bdf3ce9 in PyRun_StringFlags () from
> #24 0x00007f547c2f1018 in QgsPythonUtilsImpl::evalString(QString const&,
> QString&) ()
> from /usr/lib/libqgispython.so.2.3.0
> #25 0x00007f547c2ee291 in QgsPythonUtilsImpl::startPlugin(QString) () from
> #26 0x00000000006a080a in QgsPluginRegistry::loadPythonPlugin(QString) ()
> #27 0x00000000007bd8b2 in QgsPluginManager::loadPlugin(QString) ()
> #28 0x00000000007cafb3 in
> QgsPluginManager::pluginItemChanged(QStandardItem*) ()
> #29 0x00000000007fc46c in ?? ()
> #30 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject
> const*, int,
> void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
> #31 0x00007f54a622be2f in QStandardItemModel::itemChanged(QStandardItem*)
> () from
> #32 0x00007f54a622bee6 in ?? () from
> #33 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject
> const*, int,
> #34 0x00007f54a696a407 in QAbstractItemModel::dataChanged(QModelIndex
> const&,
> QModelIndex const&) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
> #35 0x00007f54a622c3a0 in ?? () from
> #36 0x00007f54a622ce5d in QStandardItem::setData(QVariant const&, int) ()
> from
> #37 0x00007f54a622f9f0 in QStandardItemModel::setData(QModelIndex const&,
> QVariant
> const&, int) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
> #38 0x00007f54a621e514 in QSortFilterProxyModel::setData(QModelIndex
> const&, QVariant
> #39 0x00007f54a623f219 in QStyledItemDelegate::editorEvent(QEvent*,
> QAbstractItemModel*, QStyleOptionViewItem const&, QModelIndex const&) ()
> from
> #40 0x00007f54a61a0a92 in ?? () from
> #41 0x00007f54a61a6e0b in QAbstractItemView::edit(QModelIndex const&,
> QAbstractItemView::EditTrigger, QEvent*) () from
> #42 0x00007f54a61a0d85 in
> QAbstractItemView::mouseReleaseEvent(QMouseEvent*) () from
> #43 0x00007f54a61ca12e in QListView::mouseReleaseEvent(QMouseEvent*) ()
> from
> #44 0x00007f54a5cfcc9a in QWidget::event(QEvent*) () from
> #45 0x00007f54a609adfe in QFrame::event(QEvent*) () from
> #46 0x00007f54a61aa013 in QAbstractItemView::viewportEvent(QEvent*) () from
> #47 0x00007f54a690c656 in
> QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*)
> () from
> #48 0x00007f54a5cad6ac in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #49 0x00007f54a5cb3e7d in QApplication::notify(QObject*, QEvent*) () from
> #50 0x00007f54a7b45feb in QgsApplication::notify(QObject*, QEvent*) () from
> /usr/lib/libqgis_core.so.2.3.0
> #51 0x00007f54a690c4ed in QCoreApplication::notifyInternal(QObject*,
> QEvent*) () from
> #52 0x00007f54a5cb3633 in QApplicationPrivate::sendMouseEvent(QWidget*,
> QMouseEvent*,
> QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from
> #53 0x00007f54a5d252fb in ?? () from
> #54 0x00007f54a5d23d6c in QApplication::x11ProcessEvent(_XEvent*) () from
> #55 0x00007f54a5d4b6c2 in ?? () from
> #56 0x00007f54a208f526 in g_main_context_dispatch () from
> /lib/x86_64-linux-gnu/libglib-2.0.so.0
> #57 0x00007f54a208f878 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
> #58 0x00007f54a208f91c in g_main_context_iteration () from
> #59 0x00007f54a6939725 in
> QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
> () from
> #60 0x00007f54a5d4b776 in ?? () from
> #61 0x00007f54a690b0bf in
> QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from
> #62 0x00007f54a690b3b5 in
> QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
> #63 0x00007f54a6150d4c in QDialog::exec() () from
> #64 0x00007f547986278f in ?? () from
> /usr/lib/python2.7/dist-packages/qgis/gui.so
> #65 0x00007f547bec6854 in PyEval_EvalFrameEx () from
> #66 0x00007f547bec88fd in PyEval_EvalCodeEx () from
> #67 0x00007f547bec6558 in PyEval_EvalFrameEx () from
> #68 0x00007f547bec88fd in PyEval_EvalCodeEx () from
> #69 0x00007f547bec8be2 in PyEval_EvalCode () from
> #70 0x00007f547bdf3ce9 in PyRun_StringFlags () from
> #71 0x00007f547c2edaa9 in QgsPythonUtilsImpl::runStringUnsafe(QString
> const&, bool)
> () from /usr/lib/libqgispython.so.2.3.0
> #72 0x00007f547c2ef2a3 in QgsPythonUtilsImpl::runString(QString const&,
> QString,
> bool) () from /usr/lib/libqgispython.so.2.3.0
> #73 0x000000000053848f in QgsPythonRunnerImpl::runCommand(QString,
> QString) ()
> #74 0x00007f54a7c656a2 in QgsPythonRunner::run(QString, QString) () from
> #75 0x0000000000505a2a in QgisApp::showPluginManager() ()
> #76 0x00000000007ee245 in ?? ()
> #77 0x00007f54a692077a in QMetaObject::activate(QObject*, QMetaObject
> const*, int,
> #78 0x00007f54a5ca7572 in QAction::triggered(bool) () from
> #79 0x00007f54a5ca8f43 in QAction::activate(QAction::ActionEvent) () from
> #80 0x00007f54a60d32f9 in ?? () from
> #81 0x00007f54a60d7829 in ?? () from
> #82 0x00007f54a5cfcc9a in QWidget::event(QEvent*) () from
> #83 0x00007f54a60db62b in QMenu::event(QEvent*) () from
> #84 0x00007f54a5cad6cc in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #85 0x00007f54a5cb3e7d in QApplication::notify(QObject*, QEvent*) () from
> #86 0x00007f54a7b45feb in QgsApplication::notify(QObject*, QEvent*) () from
> #87 0x00007f54a690c4ed in QCoreApplication::notifyInternal(QObject*,
> QEvent*) () from
> #88 0x00007f54a5cb3633 in QApplicationPrivate::sendMouseEvent(QWidget*,
> QMouseEvent*,
> #89 0x00007f54a5d2562c in ?? () from
> #90 0x00007f54a5d23d6c in QApplication::x11ProcessEvent(_XEvent*) () from
> #91 0x00007f54a5d4b6c2 in ?? () from
> #92 0x00007f54a208f526 in g_main_context_dispatch () from
> #93 0x00007f54a208f878 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
> #94 0x00007f54a208f91c in g_main_context_iteration () from
> #95 0x00007f54a6939725 in
> () from
> #96 0x00007f54a5d4b776 in ?? () from
> #97 0x00007f54a690b0bf in
> #98 0x00007f54a690b3b5 in
> #99 0x00007f54a6910b89 in QCoreApplication::exec() () from
> #100 0x00000000004f28f3 in main ()
> gdb returned 0
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlMpv/AACgkQ/NedwLUzIr69GwCfUaosDL4X2l2ot2Y9NgSf/9+3
> KL4AniDBPns8e4eJZvAANvBEx/5sP1e1
> =jDLm
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140319/fdd6349f/attachment-0001.html>
