[Qgis-developer] qgis server: png8 broken?
Andreas Neumann
a.neumann at carto.net
Thu Mar 20 12:29:03 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Paolo,
I have the same issue on Ubuntu 12.04 servers. I discussed this with
Marco Hugentobler and he wasn't able to reproduce the issue on his
machine. My assumption is that it may be a some sort of library issue
and my hope is that this issue will go away once Ubuntu 14.04 is
released with newer qt and graphic libraries.
Here is what I found about the issue:
- - it only happens for purely black and white and purely grayscale output
- - if you have only the slightes bit of color you are fine. It is good
enough to e.g. have a gray or 230,230,229 - which still looks
identical to 230,230,230 - the issue is gone
As a workaround you could undo the commit titled:
Revision 8990b66eed2f00253653e64c0ceb695c08a359b7: WMS server: even
more performant png8 conversion
I would love to see this fixed or gone as well. It is annoying for me
to always have to patch QGIS server after each update.
Andreas
Am 20.03.2014 19:07, schrieb Paolo Cavallini:
> Hi all. If I configure une layer as png8, the server displays an
> unreadable image: anyone confirms? qgis 2.2 on Debian wheezy. All
> the best. _______________________________________________
> Qgis-developer mailing list Qgis-developer at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTK0F7AAoJELiCsGDopvBCcqsIAJL+N8Ap3fPU31qxr1EmJIad
vAU1cI/tmoiG5p3oVoUT7lrMhFsJLIetfNeywfcb0QX1sC0eufTbj1c0x9eHYREi
8FKW+Q4CLdEV4NKUXELiInJTdDvWqEDZXtrvqABjr4YWrQRNEb/BMWkZJQmsKkpe
s0i71y7/iJjo2ZJ+Sk1Lx5tPH17PoMFqUJjbgvfRYzgtF4EfHOd2x53rmqmu6htO
WOmBBKm4KYgp3imTaZltnhFEC0Ezy5AhqsxU6YqZOxaXQtEzy2Fa651AzlqCTnb0
ORrA/rOFYVtKCkTDAhW+0WnlUvAkcAtA2bMsAYq9Eaw1pJEtnp8+tnjFifcXkWo=
=H0jG
-----END PGP SIGNATURE-----
